Can't drag and drop attachments between accounts, folders and out of Outlook into browsers.
Niv K 20 Reputation points
2026-07-30T23:42:46.83+00:00
Three days ago I stopped being able to drag and drop attachments and emails from Outlook.
This includes:
  • Dragging attachments into a new email from the same account or different account (only Copying and Pasting attachments to a new email works without having to save the attachment and attach manually).
  • Dragging attachments into a folder on the computer
  • Dragging any attachment - Regardless of file type - into a browser to upload files. I usually work with PDF Files and have had no problems until three days ago.
  • Dragging an email to another folder within the same account.
I have searched on the forum and found answers relate to this issue only occurring with the New Outlook. I can confirm I am still only using Classic Outlook and have also tried clearing the cache as recommended previously.
Please advise when this will be fixed, as it has a significant impact on workplace efficiency. Saving the attachment to a folder and then uploading, or dragging from the folder to a browser adds extra, unnecessary steps.
The image attached below shows what happens when I try to drag the attachment. This is just inside the email, and the circle with diagonal line through it stays when attempting to drag anywhere.
Jade Ng 15,480 Reputation points Microsoft External Staff Moderator
2026-07-31T01:31:22.25+00:00
Dear @Niv K,
Thank you for providing the detailed description of the issue. I understand how disruptive this is, especially when drag-and-drop is part of your daily workflow.
Since you have confirmed that you are using Classic Outlook and that drag-and-drop was working normally until three days ago, this behavior is not expected. Drag-and-drop actions such as moving emails between folders, dragging attachments to File Explorer, attaching files to new messages, and dropping files into browser upload windows should continue to work in Classic Outlook.
To better isolate the cause, could you please confirm the following?
  • Does the issue affect all Outlook profiles/accounts or only a specific mailbox?
  • What version of Outlook are you using? (File > Office Account > About Outlook)
  • Are you running Outlook with administrator privileges?
  • Does the issue persist after completely closing and reopening Outlook?
  • Are you using Windows 11 version 24H2, and have any Windows or Office updates been installed recently?
As initial troubleshooting, please try:
1.Disable the Outlook setting “Optimize for compatibility”:
  • Select the File tab, then select Options.
  • On the General tab, under User interface options, select the option Optimize for best appearance.
Untitled
2.If you use an Exchange account, try temporarily toggling Cached Exchange Mode and test again. Turn on Cached Exchange Mode
3.Repair Outlook
  • Close Outlook and all Office apps.
  • Open Setting > App > Installed apps
  • Find Outlook for Window and right-click on it and select Advanced option.
  • Choose Repair Option.
  • Restart your computer after the repair is complete.
4.Create a new Outlook profile and test whether the behavior persists. Create an Outlook profile
There was a previously identified Microsoft issue that prevented drag-and-drop operations in Classic Outlook on certain Windows 11 24H2 systems after specific Windows updates. Microsoft later released a fix through subsequent Windows updates. For more detail, please refer to: Unable to drag and drop emails to folders in classic Outlook
If the issue persists after trying the steps above, please let me know, and I'll be happy to help you further.
I appreciate your cooperation and look forward to your update.
0 additional answers
