How to fix "High Definition Audio Device" on my Windows 11?
Krish Mathur 40 Reputation points
2026-07-29T08:41:30.17+00:00
Since a couple of days I've been encountering this issue of my laptop speakers randomly not playing audio, even if I'm playing a video with audio, the sound just "disappears", after multiple restarts only is when the audio returns to play from the speakers, there's no such issue when i connect my Bluetooth earphones. As per previous forums questions, I've also tried restarting the audio services, re-installing audio drivers, but nothing seems to be working. I'm suspecting it to be driver issue and not a hardware issue as the hardware diagnostics show no result of a failing hardware.
I noticed a greyed out, hidden driver named "High Definition Audio Device", the device status shows the following:
Currently, this hardware device is not connected to the computer. (Code 45)
To fix this problem, reconnect this hardware device to the computer.
Driver version : 10.0.26100.8737
Driver date: 18/06/2026
GsN5034 - IA 76,475 Reputation points Independent Advisor
2026-07-29T09:19:06.88+00:00
Hello, thank you for reaching out to Microsoft Q&A.
Yes, it appears to be an audio driver-related issue. Try these troubleshooting steps and see if it resolves the issue -
On the Device Manager -
Right-click the 'High Definition Audio Device' driver, Select Uninstall device > *select the "Attempt to delete the driver software for this device " checkbox, and then click Uninstall.
Then, restart your computer and check the audio output.
Note: Windows will automatically reinstall the drivers during this restart.
If you are still having issues,
1.
Visit your PC manufacturer's website.
Enter your computer serial./model number.
Go to the Drivers & Downloads section.
Download the latest high-definition audio device driver and install it.
Restart your computer and check the audio output.
If you are having difficulty finding the drivers,
Type msinfo in the search bar on the taskbar and click Enter.
Post a Screenshot of the resulting dialog box.
0 additional answers
