Compatible Printers and Scanners
Susan 0 Reputation points
2026-07-16T14:03:48.4466667+00:00
Ever since I upgraded my Surface, I have had nothing but problems with connecting printers and scanners to it. After some research, I found out it is because the processor on the Surface I purchased isn't compatible with most printers and scanners. Does anyone know of any printers and scanners that reliably connect with the Snapdragon processor? My laptop shows the processor as: Snapdragon(R) X 10-core X1P64100 @ 3.40 GHz (3.42 GHz).
I need a reliable connection for my business. Specifically, we want a printer with a scanner and a separate receipt scanner that can all hook up to my Surface. Right now I have an Epson WF 4830. It worked great with my old Surface but I have to jump through hoops to get it to print with this new one.
Windows for business | Windows Client for IT Pros | User experience | Print, fax, and scan
  1. Pavle Peković 6,845 Reputation points Volunteer Moderator
    2026-07-16T14:52:37.1833333+00:00
    If you want to purchase a new printer and scanner today, maybe it's a good idea to purchase mopria certified printer and/or scanner. Check if the specific model is mopria certified here: https://mopria.org/certified-products
    If you want to know more about Mopria and Windows Protected Print Mode, check this article: https://learn.microsoft.com/en-us/windows/modern-print/windows-protected-print-mode/windows-protected-print-mode
