How do I restore my files and settings from a lost Windows 11 laptop to a newly set-up device?
Durden 20 Reputation points
2026-07-15T17:41:38.9333333+00:00
​I recently lost my old Windows 11 laptop and had to purchase a replacement. When I bought the new one, the person at the store went ahead and completed the initial Windows setup for me.​Because they already signed in and set it up as a completely new device, I missed the initial prompt to restore from a previous backup. How can I pull down and restore my old Windows settings, files, and apps (which should be tied to my Microsoft account/OneDrive) onto this new laptop now that it's already up and running?
​Do I need to perform a factory reset to get the restore prompt back, or is there a way to sync everything from my old device as it is right now?
Windows for home | Windows 11 | Recovery and backup
DaveM121 933.5K Reputation points Independent Advisor
2026-07-15T18:21:10.5766667+00:00
Did you use OneDrive to sync your files on the laptop that was lost?
If so, there are two options available.
1
Open the Settings App.
Go to Accounts - Your Info.
ON that settings window, you should see either the option to 'Switch to a Local account' or the option to 'Stop automatically logging into apps with this account'.
Select whichever of those two options exist, that will switch the user account to a local account.
Wait a couple of seconds, then click the option to switch to a Microsoft account login and add the details of the Microsoft account you used on the lost laptop.
Then ensure you log into OneDrive on the taskbar using that same Microsoft account.
Your files and settings should then sync down to the new laptop.
2
Otherwise, you can create a new user account on the new laptop, then sign into that account with the old Microsoft account details, then delete the new account the shop created on the laptop.
Go to Accounts - Other Users
Click 'Add Account'.
Follow the prompts to create a new account
Close the settings app
Log out of that user account
Log into your new account
Click the Start Button, type netplwiz and hit Enter
In the resulting dialog, select the old account and click 'Remove'
That's It, your new Account will replace the old account.
0 additional answers
