What are the best practices for improving Power BI report performance with large datasets?
sarah maryam 20 Reputation points
2026-07-13T13:01:54.6633333+00:00
Hello everyone,
I am learning Power BI and working with reports that contain large datasets. As the data model grows, I have noticed that report loading and visual interactions can become slower.
I would like to understand the best practices recommended by experienced Power BI users for improving report performance.
Specifically, I would appreciate guidance on the following:
  • Is a star schema always the preferred approach for large datasets?
  • When should Import mode be used instead of DirectQuery?
  • What are the most common DAX optimization techniques that improve performance?
  • Does reducing the number of calculated columns have a noticeable impact?
  • Which tools do you typically use to identify performance bottlenecks before publishing a report?
I have reviewed Microsoft's documentation on Power BI performance optimization, but I would also like to learn from real-world experience and recommendations from the community.
Thank you in advance for your suggestions.
I work with Edoxi, where I regularly explore Power BI concepts and learning resources. While researching report optimization, I wanted to understand how experienced Power BI professionals approach performance tuning in real-world projects.
Microsoft 365 and Office | Subscription, account, billing | For business | Other
Liora D 18,920 Reputation points Microsoft External Staff Moderator
2026-07-13T13:40:48.49+00:00
Dear @sarah maryam,
I hope you’re having a good day.
Thank you for the thoughtful questions. Based on both Microsoft's guidance and what I commonly see in real-world Power BI projects, most performance challenges with large datasets can usually be traced to three areas: data model design, storage mode selection, and DAX complexity.
1. Is a star schema always the preferred approach?
In most large-scale Power BI models, yes. A star schema is generally the recommended design because it simplifies relationships, improves model compression, and typically results in faster query performance compared to highly normalized or complex snowflake models.
A common best practice is to keep:
  • Fact tables for transactional data.
  • Dimension tables for descriptive attributes.
  • Relationships as simple and as few as possible.
2. When should Import mode be used instead of DirectQuery?
As a general rule:
  • Import** **mode provides the best report performance and user experience because data is loaded into the Power BI model.
  • DirectQuery is usually appropriate when near real-time data is required or when dataset size makes importing impractical.
If acceptable refresh intervals can meet business requirements, I typically recommend Import mode first because it usually delivers significantly faster visual interactions and report loading times.
3. Common DAX optimization techniques
Some techniques that frequently help improve performance include:
  • Using variables (VAR) to avoid recalculating the same expression multiple times.
  • Prefering measures over calculated columns when appropriate.
  • Minimizing the use of expensive iterator functions such as SUMX, FILTER, and ADDCOLUMNS when simpler alternatives exist.
  • Reducing unnecessary context transitions.
  • Keeping filter logic as simple as possible.
Even small DAX changes can have a noticeable impact when working with large datasets.
4. Does reducing calculated columns help?
Yes, it often does.
Calculated columns consume storage in the model and can increase refresh times. In larger models, reducing unnecessary calculated columns can improve both memory usage and refresh performance.
When possible, many transformations are better performed:
  • In Power Query during data preparation.
  • At the source system or data warehouse layer.
5. Which tools help identify bottlenecks?
The tools I use most often are:
  • Performance Analyzer in Power BI Desktop.
  • DAX Studio for query and server timing analysis.
  • VertiPaq Analyzer for understanding model size and compression efficiency.
Performance Analyzer is usually the easiest starting point because it quickly identifies which visuals or queries contribute most to report latency.
In my experience, the biggest performance gains usually come from:
  1. Building a clean star schema.
  2. Using Import mode whenever feasible.
  3. Reducing model size.
  4. Writing efficient DAX.
  5. Testing with Performance Analyzer and DAX Studio before publishing.
Additionally, for Power BI-specific topics, you may also wish to post your question in the Power BI Community: Power BI Community. Many Power BI experts, MVPs, consultants, and experienced community members actively participate there and can often provide real-world performance optimization recommendations based on production deployments and large-scale datasets.
I hope this helps provide a solid starting point for your SC-401 and Power BI learning journey.
Warm regards,
If the answer is helpful, please select "Yes" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
2026-07-15T10:58:27.6666667+00:00
Thank you for the comprehensive explanation. Your insights on star schema design, storage modes, and DAX optimization clarified many of the questions I had.
One additional lesson I've come across while exploring Power BI at Edoxi is that reducing the amount of data loaded into the model can make a significant difference. Removing unused columns, filtering unnecessary historical records, and performing transformations in Power Query or at the data source often results in faster refreshes and more responsive reports.
I've also found that reviewing high-cardinality columns and simplifying relationships helps keep models efficient as datasets grow. Combining these practices with Performance Analyzer and DAX Studio seems like a practical approach to identifying bottlenecks before publishing.
Thanks again for taking the time to share your experience. This discussion has given me several ideas that I'll be exploring further in my Power BI learning and practical work at Edoxi.
0 additional answers
