Brother MFC Scanner not working
MS Acct Leigh Bond 20 Reputation points
2026-07-10T20:07:30.52+00:00
How to get my Brother MFC-8480NW scanner to work? It keeps telling me to restart. Error message goes like this:
Setup Complete
Please click OK and then restart your PC for these settings to tak effect (WA006-0100)
Version 25H2
Ivan B 124.1K Reputation points Independent Advisor
2026-07-10T20:49:31.44+00:00
Hii,
Try you can use the Windows app: https://apps.microsoft.com/detail/9wzdncrfj3pv?hl=en-US&gl=US
Do the following: go to the Start menu > Settings > Bluetooth & devices > Printers & scanners > Click on the printer/scanner > click on the "Scan settings" tab > "More scan and printer settings" > select the Brother printer > right-click and select "Start scan".
or
If the scanner option is missing, do the following:
Go to Start menu > Settings > Bluetooth & devices > Printers & scanners > select a Brother printer > Remove device
https://support.brother.com/g/b/downloadlist.aspx?c=us_ot&lang=en&prod=mfc8480dn_us&os=10013
Access the link below, download the full driver package, and run it as an administrator.
Try scanning and see if it works using the top feeder.
Let me know if it worked or not.
While this is not a Microsoft website, it is the official site of [MFC-8480DN/Brother].
0 additional answers
