I know it sounds cliche but if this just happened recently you may want to do a full restart of your computer. This can happen when Windows Update updates a driver component of your audio chipset. It often needs a reboot to complete or put the last part of the changes fully into place. When you get back from the restart if it is still not working or changed you can check if your Windows update attempted an update that failed. A big question here is how long has it been this way?
How do I fix "No audio devices are installed"?
Krystal Mondillo
20
Reputation points
I have no sound on the computer, I can no longer use the microphone, the speaker in the bottom right toolbar has an x over it and when I go into sound, it says "no audio devices are installed." What do I need to do?
1 additional answer
CCtheCompuGuy 160 Reputation points2026-07-04T05:04:01.0066667+00:00 Also would be useful to know what brand(ie Dell, Lenovo, Acer, HP etc) of computer it is and if it is a laptop or a desktop computer.
