I have had multiple problems logging into install visio trial
Arthur Pini 0 Reputation points
2026-07-02T13:47:44.8033333+00:00
I tried to log in to install Visio. Got to a Copilot page which was confusing.
When I finally got to a login in it required a PIN
Used forgot pin to try and update PIN. While entering required information the screen would revert to previous screen
Locked in a forever loop while trying to use one of your prodects.
I have wasted an hour on this mess
Microsoft 365 and Office | Visio | For home | Windows
  1. Alina Le 5,000 Reputation points Independent Advisor
    2026-07-02T14:40:38.1633333+00:00
    Hi @Arthur Pini
    As you have shared, I understand that you were trying to install a Visio trial, but instead of reaching a straightforward installation process, you were redirected through several sign in pages, encountered a PIN request, and then became stuck in a repeated cycle when attempting to reset the PIN.
    To confirm the situation and suggest the troubleshooting steps in the right direction, may I confirm a few points:
    1/ Which version of Visio are you trying to install? For example, Visio Plan 1 Trial, Visio Plan 2 Trial, Visio Standard, or Visio Professional.
    2/ Are you using a personal Microsoft account or a work/school account to sign in?
    3/ When the PIN prompt appears, does it mention "Windows Hello" anywhere on the screen? Is the PIN request appearing in a Windows security pop up window, or directly inside the web browser page?
    4/ When you select "Forgot PIN", does the process return to the previous screen immediately, or does it happen after entering specific information?
    5/ Do you see any error message or code before the page returns to the earlier screen?
    You can send me a screenshot or describe more about this issue so I can understand your needs better for further assistance.
    AA - BIO> > @ Image 1
    Looking forward to hearing from you
    Kind regards,
    If you have extra questions about this answer, please click "Comment"
