How to fix wifi
Khang Nguyễn 45 Reputation points
2026-07-02T09:22:10.5033333+00:00
my laptop lags when playing games then the wifi shut down and cant be connected anymore (I lost the wifi icon). I have to restart the laptop to use it again. I tried update wifi driver, reset it but it didnt work
TaoLi 112.9K Reputation points Independent Advisor
2026-07-02T09:57:59.02+00:00
Open Device Manager (right-click the Start menu > Device Manager), expand the "Network adapters" section, and locate your Wi-Fi device.
Right-click the device, check the box for "Delete the driver software for this device," and select "Uninstall device."
Restart your computer after the uninstallation is complete; the system will automatically reinstall the basic driver.
If the issue persists, you can try using the driver provided by Intel:
Download and install the driver for your specific model from your computer manufacturer's official website, or use Intel's official driver tool:
https://www.intel.com/content/www/us/en/support/detect.html
Disclaimer: This link points to a non-Microsoft website. While the content appears accurate and safe, the site may contain third-party advertisements. Please distinguish between advertisements and official download links to avoid accidentally clicking on content that might promote PUPs/PUAs (Potentially Unwanted Programs). It is recommended to verify the source and file name before downloading or installing any files.
0 additional answers
