My Surface Pro 11 will not turn on unless I plug it in
Janiella Shirley 0 Reputation points
2026-07-01T17:55:42.29+00:00
My Surface Pro 11 will not turn on even with a full battery unless I have it plugged in. Can this be resolved?
  1. Clary-N 15,375 Reputation points Microsoft External Staff Moderator
    2026-07-02T00:38:37.8666667+00:00
    Hi Janiella Shirley,
    Thank you for reaching out. I'm sorry to hear your Surface Pro 11 will only power on when connected to the charger.
    The AI Answer has already provided the recommended troubleshooting steps for this issue, so I'd suggest working through those steps first, particularly checking the battery icon status, performing the force restart and ensuring all available Surface and Windows updates are installed. These are the primary troubleshooting steps Microsoft recommends when a Surface does not operate correctly on battery power.
    If Windows is able to start while plugged in, you can also open the Surface app and check under Help & Support for any pending Surface firmware updates, as firmware updates can sometimes address battery detection or power management issues.
    Once you've had a chance to try those steps, could you let me know:
    • What battery percentage is reported when Windows is running?
    • Does the battery icon show any warning, such as a red X or "Battery not detected"?
    • If you unplug the charger after the device starts, does it shut down immediately or continue running for a while?
    • Has this issue started recently, such as after an update or has it been happening since you first received the device?
    These details can help determine whether we're dealing with a power management issue or a potential hardware problem. If the battery appears fully charged but the Surface will not power on without AC power or if the battery is not detected, the issue may be hardware-related and would likely require service.
    As a forum moderator, I'd also like to note that this is a community support forum, so we don't have access to device diagnostics or repair systems. If the issue ultimately requires service, you can submit a repair request if still under warranty or bring your surface to a nearby Microsoft Authorized Service Provider for in-person evaluation and assistance.
    Please let me know the results and I'll be happy to help further.
    If you have extra questions about this answer, please click "Comment".
  2. AI answer
    2026-07-01T17:55:57.8033333+00:00
    Yes, this can often be resolved with standard Surface battery and power troubleshooting. Use these steps in order:
    1. Disconnect accessories and charge
      • Remove all accessories: USB drives, SD cards, external monitors, Type Cover, Surface Dock, and other USB devices.
      • Connect the original power supply designed for Surface Pro 11.
      • Charge for at least 15 minutes, then close and reopen the keyboard/cover and press the power button.
    2. Check the battery icon status (once Windows is running)
      • If the battery icon shows a red X and the device turns off as soon as it is unplugged, the battery is not detected. In this case, go to Device service and repairs to start a service request.
      • If it shows “Plugged in, not charging” (lightning or plug symbol) while connected:
        • Confirm the power supply is the correct one for Surface Pro 11.
        • Disconnect high‑power accessories and see if charging behavior changes.
    3. Force a restart
      If it appears to have power but won’t behave correctly on battery:
      • Press and hold the power button for about 20 seconds until the logo screen appears.
      • After restart, install the latest Surface and Windows updates.
    4. Battery driver reset (do NOT use on Arm-based Surface)
      Surface Pro (11th Edition) is listed among Windows Arm-based devices, so do not uninstall battery drivers on this model; the only way to restore them would be a full system reset.
    5. If it still only works when plugged in
      • If the device will not turn on at all on battery, or the battery is not detected, it likely requires hardware service.
      • Use the service options: send to Microsoft, find in‑person support, or self‑repair (if technically experienced and with proper parts and guides).
    If, after these steps, Surface Pro 11 still cannot run on battery, the issue is not user-fixable and the device should be sent to Microsoft or an authorized service center for inspection and repair.
