Outlooks keep crashing
Catherine Stannard 140 Reputation points
2026-06-30T07:23:10.6566667+00:00
When i go to send an email, try to right click on a spelling mistake or add a snapshot - The email crashes and closes down not even saving into drafts? please can anyone advise?
Moderator note: thread updated with version of Outlook (classic Outlook for Windows)
James Burney 150 Reputation points
2026-06-30T09:02:53.4133333+00:00
We have some users that were affected by this issue. The version was 20026.20182. Typical fixes such as Quick Repair did not resolve the issue.
Updating to the latest version of Office apps resolved the issue for the users. The latest version is 20131.20090 and was released on June 25.
To update the apps on one machine, go to: Outlook > File > Office Account > Update Options > Update Now
14 additional answers
  1. Danilevicius, Benas 0 Reputation points
    2026-06-30T13:39:15.87+00:00
    Tried most of these only option that seemed to work was running cmd as admin with elevated rights and running the following command to change back to the older version of Outlook (This is only for classic) : "%programfiles%\Common Files\Microsoft Shared\ClickToRun\officec2rclient.exe" /update user updateversion=16.0.20026.20168
  2. Gabriel Guardiola 5 Reputation points
    2026-06-30T16:14:43.56+00:00
    Performing an Online Repair on MS365 has worked for me, however it has been inconvenient having to remote into every user's computer to do it. Running this script in powershell as admin allows you update MS365 remotely, without having to remote in to do the online repair/update: Start-Process "$env:ProgramFiles\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe" -ArgumentList "/update user repair=true forceappshutdown=true"
    The user will see an update process bar which they cannot close, once it is completed they should be able to reopen Outlook and try again.
  3. Daniel Segura Salazar 0 Reputation points
    2026-07-01T19:24:58.0933333+00:00
    Hi
    Does any one know how to download the office offline installer, normaly I was able to create the XML file from the web site https://config.office.com/deploymentsettings, then with CMD download the package with all the binaries and files necesaries using the command setup.exe /download configuration.xml, it downloads and the with the command setup.exe /configure configuration.xml it installed. But now it fails to be installed, there is something wrong with the installer.
    This is necessary to make the update process to 2606 with the fix of this Outlook error, because online repair takes a lot to be completed
    If anyone knows how to get this offline installer and use it, I will be more than glad.
    Regards
  4. JK 0 Reputation points
    2026-07-02T07:57:31.3233333+00:00
    A update that was done behind the scenes by Microsoft has resolved the issue as this morning everyone has turned their machines on and the issue is gone despite no updates being manually done so it appears a blind update has been done and resolved the issue, spoke to me friend who has Outlook 2016 and he's is now working also.
    Hopefully everyone else is now back up working.
