how to stop emails from going to the archive folder
Jane Mallon 0 Reputation points
2026-06-27T13:46:38.92+00:00
I don't use the archive folder when I delete an email how to I stop using the archive folder
Vasil Michev 127.8K Reputation points MVP Volunteer Moderator
2026-06-27T14:44:50.7633333+00:00
Are you using the "backspace" key to delete the email? Unfortunately, said key is hard-mapped to "archive" the item instead, that is move it to the Archive folder. You can use the Delete key instead.
If you feel comfortable working with the registry, you can also disable the "hit Backspace to archive items" behavior, as explained for example here: https://office365itpros.com/2022/09/02/outlook-archive-folder/
0 additional answers
