Old authenticator info lost due to not backing up phone to cloud.
PATRICK ANTHONY C. PALMA 0 Reputation points
2026-06-26T14:11:50.9366667+00:00
How do I get all my pass authenticator info back that I did not back up?
Microsoft Security | Microsoft Authenticator
    2026-06-26T14:12:11.55+00:00
    If the phone was not backed up to the cloud and there is no Authenticator backup, the original app data (including most codes) cannot be recovered. Recovery options depend on the type of accounts and what was backed up, if anything:
    1. If Microsoft Authenticator cloud backup was enabled (iOS or Android)
      Authenticator can restore saved account credentials to a new device of the same platform type only:
      • iOS backup → can only be restored on iOS.
      • Android backup → can only be restored on Android.
      For iOS, requirements include:
      • A personal Microsoft account as the recovery account.
      • Being signed in to iCloud, with iCloud Drive, iCloud Keychain, and iCloud Backup enabled.
      • In Authenticator: Settings → Backup → iCloud backup turned on.
      To restore on iOS:
      1. Enable iCloud Drive, iCloud Keychain, and iCloud Backup on the new device.
      2. Install Microsoft Authenticator.
      3. Sign in with the same personal Microsoft account used for backup.
      4. Authenticator will restore the saved credentials; then sign in to each account as required.
      What can be restored:
      • Microsoft personal accounts
        • If using only a 30‑second one‑time password (OTP): the OTP configuration is restored and codes work again.
        • If using passwordless sign‑in: only the account name is restored; sign in again to re‑enable passwordless.
      • Work or school accounts: only the account name is restored; sign in again.
      • 3rd‑party accounts (Amazon, Facebook, Gmail, etc.): OTP configurations are restored and codes work again.
    2. If no Authenticator/cloud backup exists or it was on a different platform
      If the phone was never backed up (or the backup is inaccessible) and Authenticator’s own cloud backup was not enabled, the OTP secrets stored on the old device are lost. In that case:
      • Authenticator cannot reconstruct old codes.
      • Each account must be recovered and re‑added manually using that service’s recovery process.
      Typical steps per account:
      • Use the account’s “Can’t access your account?” or recovery form.
      • Prove identity using email, SMS, backup codes, or support.
      • Once signed in, go to that service’s security/MFA settings and remove the old Authenticator registration.
      • Set up Microsoft Authenticator again by scanning the new QR code or following the service’s MFA setup instructions.
    3. If locked out of Microsoft accounts because of lost Authenticator
      • Work or school account: follow the guidance in “I’ve lost access to my security info” to replace security info and wait out any enforced period if required.
      • Personal Microsoft account (Outlook/Hotmail, etc.): use the Microsoft account recovery form and follow the prompts to regain access, then re‑add Authenticator.
    Going forward, enable Authenticator cloud backup (and, on iOS, iCloud services) so future device changes do not cause loss of codes.
