How to scan from printer
Patricia Hairston 20 Reputation points
2026-06-25T22:36:57.8766667+00:00
Please show me How I can use my printer to scan a document
Ivan B 123.9K Reputation points Independent Advisor
2026-06-25T23:11:16.6033333+00:00
Hii,
What is your printer model?
If it is already set up on your PC: https://support.microsoft.com/en-us/Windows/Hardware/Printer/install-and-use-a-scanner-in-windows
You can use the Windows app: https://apps.microsoft.com/detail/9wzdncrfj3pv?hl=pt-BR&gl=BR
or
Do the following: go to the Start menu > Settings > Bluetooth & devices > Printers & scanners > Click on the printer/scanner > click on the "Scan settings" tab > "More scan and printer settings" > select the Brother printer > right-click and select "Start scan".
Try scanning and see if it works using the top feeder.
Let me know if it worked or not.
0 additional answers
