Hearing aid connection to Blue tooth
Lindsay Gibson 20 Reputation points
2026-06-25T21:19:17.5033333+00:00
HEARING AID DOES NOT CONNECT TO BLUETOOTH. IT COMES UP WITH " Your Windows PC doesn't support LE Audio. Some features might not be available for your hearing aids."
Any solutions?
EmilyS726 268.6K Reputation points Independent Advisor
2026-06-25T21:54:30.5233333+00:00
Hello
To find out if your Windows 11 supports LE Audio, you can go to Settings > Bluetooth & devices > Devices, Scroll down to the Devices Settings section. See if you have the option of "Use LE Audio when available ", If so, make sure you turn it on. If not, it means your Windows doesn't support it. Further instruction: https://support.microsoft.com/windows/check-if-a-windows-11-device-supports-bluetooth-low-energy-audio-2b79c085-0353-4467-8306-ebb2657a91de
If it is not there, you will have to wait for the computer's manufacturer (such as Dell, Lenovo, depending on what brand yours is) to release the LE Audio Bluetooth driver in order for Windows to have this feature.
0 additional answers
