DxDiagn dont load
Yisus 5 Reputation points
2026-06-25T15:03:03.5033333+00:00
Hi there, I recently did a factory reset on my operating system, deleting all files and choosing the cloud download option. I want to play some games, but it seems like DirectX isn't working. When I open the Run dialog and type dxdiag to launch the tool, I get the following error: 'DXDIAGN.DLL failed to load'.
I've already tried reinstalling DirectX, updating the Visual C++ redistributables, and updating all my drivers. Additionally, I have already run both the sfc /scannow and DISM /Online /Cleanup-Image /RestoreHealth commands, but absolutely nothing has worked so far.
Ivan B 124.1K Reputation points Independent Advisor
2026-06-25T15:38:08.3733333+00:00
Hi ,
Search for msinfo32.exe in the search bar, take a screenshot, and post it here so can see the correct laptop model or desktop configuration.
1 additional answer
  1. Senthil kumar 2,500 Reputation points
    2026-06-25T17:37:21.3033333+00:00
    Hi @Yisus
    Check your memory and check PCI Express slot details its down show your graphics card details. take screenshot and share here. will check what is issue there.
    Thanks.
