usb port not registering my keyboard keeps saying needs troubleshooting
brayden bridges 0 Reputation points
2026-06-18T20:29:06.26+00:00
when i plug my keyboard in it wont work i figure out what was happening and it said that it needs troubleshooting and that its also saying that device unknown how do i fix it
John Jefferson Doyon 88,510 Reputation points Independent Advisor
2026-06-19T07:42:04.36+00:00
Thanks for confirming.
Since the keyboard works on the left USB port and other USB devices also fail on the right USB port, this suggests the issue is with the USB port itself or its driver rather than the keyboard.
Try these steps:
  • Shut down the laptop completely.
  • Unplug the charger and any USB devices.
  • Hold the power button for 15-20 seconds.
  • Start the laptop and test the right USB port again.
If that does not help, open Device Manager and expand Universal Serial Bus controllers. Right-click each USB Root Hub and Generic USB Hub, then select Uninstall device. Restart the laptop afterward. Windows should reinstall the USB drivers automatically.
What is the make and model of the laptop?
Also, did the right USB port stop working recently, perhaps after a Windows update, driver update, or physical impact to the laptop?
5 additional answers
  1. John Jefferson Doyon 88,510 Reputation points Independent Advisor
    2026-06-18T21:29:43.97+00:00
    Hi, I'm John! I will help you with this.
    Is this the same keyboard that worked before on this PC, or is it a new keyboard?
    Try plugging the keyboard into a different USB port, preferably a USB port on the back of the computer if you're using a desktop. If possible, test the keyboard on another computer to see if it is detected there.
    When Device Manager shows "Unknown Device," it can be caused by a faulty USB port, a damaged keyboard cable, or a driver issue.
    What is the make and model of the keyboard? Are you using a desktop or laptop?
    Do you see any error code when you open the properties of the "Unknown Device" in Device Manager?
  2. John Jefferson Doyon 88,510 Reputation points Independent Advisor
    2026-06-19T01:21:42.6366667+00:00
    i used this keyboard before. my computer is a laptop the brand of my keyboard is red dragon the right usb port is the problem when i plug in the keyboard on the left one it works fine.
    Thanks for the update.
    Since the keyboard works on the left USB port, the keyboard itself appears to be working normally. This points to an issue with the right USB port or its driver.
    Could you test another USB device, such as a mouse or flash drive, in the right USB port?
    If other devices also do not work there, please let us know the make and model of your laptop. That will help determine whether this is a driver issue or a possible hardware problem with the USB port.
  3. brayden bridges 0 Reputation points
    2026-06-19T06:04:41.2+00:00
    i used this keyboard before. my computer is a laptop the brand of my keyboard is red dragon the right usb port is the problem when i plug in the keyboard on the left one it works fine and no i dont see any error code when i open device manager
  4. brayden bridges 0 Reputation points
    2026-06-19T06:06:35.6033333+00:00
    i already try to put other things in it like mouses that i also use before on the laptop and it still does not work the model of my laptop is a windows 11 Lenovo
