My Bluetooth Is Gone.
Sahan Khan 40 Reputation points
2026-06-17T21:36:25.69+00:00
My Bluetooth Is Gone From My Action Center And I Keep Installing the driver but it stills dissapears. What Do I Do? (Im on windows 11 and my motherboard is a asrock a620m pro rs wifi.)
John DeV 170.2K Reputation points Independent Advisor
2026-06-18T15:23:41.8633333+00:00
I just wanted to verify with you whether your Bluetooth problem has been fixed, and you can now see its option on your computer.
Please try to check the old Sound Control Panel
Press Windows + R to open Run then type:
mmsys.cpl
Press Enter.
On the Playback tab:
Find your Bluetooth headset.
Right-click it and select Set as Default Device.
On the Recording tab:
Find your headset microphone.
2026-06-17T22:10:36.32+00:00
Hi, good day!
  • When was the last time it worked properly?
  • Have you made any changes to your computer recently?
Here are some of the things you can try.
  • Shutdown your computer
Unplug the power cable from the computer for 30 minutes, then plug it in again and turn on.
This will open Services app
Find Bluetooth Support service in the list
Right click it then select Restart
Right click it again then select Properties
Click General Tab, in the Startup Type option, choose Automatic in the drop-down list.
Click Apply and OK.
Restart your computer.
  • Please try to turn off Fast startup
Press Start then search Control panel
Under View by > select Small icons
Select Power Options
On the left side, click "Choose what power buttons do"
Click "Change settings that are currently unavailable"
Under Shutdown settings > Turn off fast startup
Power off the system then pull the power cable from the computer, wait for 15 minutes.
Power back on
I look forward to receiving your update and I'm willing to collaborate with you till we resolve the issue. Do keep me informed by clicking "Add Comment" below.
0 additional answers
