Authentication code
Tawfik, Ingy Ramzy Sedik 0 Reputation points
2026-06-17T17:16:58.7366667+00:00
I don’t see the authentication code when open the authenticator , I need the code for z scaler
Microsoft Security | Microsoft Authenticator
    2026-06-17T17:17:10.4366667+00:00
    To use Microsoft Authenticator with Zscaler, an account entry in the app must show a one-time password (OTP) code. If no code appears when opening the app or tapping the account, try these steps:
    1. Confirm the correct account entry
      • In Microsoft Authenticator, tap the account that should be used for Zscaler.
      • Look for a line similar to “One-time password code” with a 6‑digit code that changes every 30 seconds.
      • If that line exists, use that 6‑digit code in Zscaler.
    2. If no OTP code is shown for that account
      • The account may not be configured as an OTP (OATH) token in Authenticator.
      • In that case, Zscaler must provide a QR code or secret key to add a new OTP entry in Microsoft Authenticator. Use Zscaler’s instructions to:
        • Add an account in Microsoft Authenticator.
        • Scan the QR code or enter the key from Zscaler.
    3. If the account used to show a code but no longer does
      • Ensure Microsoft Authenticator is updated to the latest version.
      • If the app or device was recently changed and the OTP entry is missing, the original OTP secret might be lost. Zscaler or the organization’s admin must reset the MFA/OTP setup for that Zscaler account so it can be re-enrolled in Authenticator.
    4. If sign-in or approval is failing with “Authentication did not complete”
      • Make sure Microsoft Authenticator is unlocked on the device.
      • Ensure notifications are enabled for Microsoft Authenticator.
      • Confirm the device has network connectivity and the date/time settings are correct.
    If no OTP code appears and Zscaler does not provide a way to re-enroll, contact the organization’s IT/Zscaler administrator to reset the Zscaler MFA configuration so a new QR code can be scanned into Microsoft Authenticator.
