how do i get live help for a windows 365 issue
Inta Gertnere 20 Reputation points
2026-06-16T18:33:08.3766667+00:00
I need live help. My computer has become unable to open pdf files
Microsoft 365 and Office | Other
John Jefferson Doyon 88,610 Reputation points Independent Advisor
2026-06-16T19:06:52.3466667+00:00
Hi, I'm John! I will help you with this.
Are you getting an error message when you try to open a PDF? If so, what does it say?
As a quick test, can you right-click a PDF file, select Open with, then choose Microsoft Edge and see if the file opens?
Let me know what happens and any error message you see. That will help identify whether the issue is with the PDF app or Windows itself.
1 additional answer
    2026-06-16T18:33:37.5766667+00:00
    To get live help for a Windows 365 issue and trouble opening PDF files, use these supported options:
    1. Use the Get Help app (Windows personal account)
      1. In Windows, open the Get Help app (type "Get Help" in the Start menu search box).
      2. Enter a brief description such as "Windows 365 cannot open PDF files" to search for solutions and run any suggested troubleshooters.
      3. If the issue persists, select Contact support when prompted.
      4. Choose the affected product/service and follow the prompts.
      5. Select a contact method:
        • Chat with a support agent in your web browser; or
        • Provide a phone number for a call back; or
        • If it’s hardware-related, submit a repair request.
    2. Use Microsoft 365 / Office support options
      • Go to the Microsoft Office Support home page and use the Contact Us option at the bottom of the page to reach support by phone, chat, or email for issues related to Office apps and PDF handling.
      • For Microsoft 365 for business, an admin can sign in to the Microsoft 365 admin center, select Support > Help and support, enter the issue, and choose Contact support to get live help.
    3. Check current Office/Windows issues and service health
      • Review Fixes or workarounds for recent Office issues to see if PDF or related problems are listed.
      • If using Microsoft 365, an admin can check the Service health page in the Microsoft 365 admin center to confirm there is no ongoing service issue.
    4. Community and self-help resources
      • Search for "PDF won’t open" or similar in the online help and community forums for Microsoft 365/Office.
      • Use the search box on https://support.microsoft.com to look for troubleshooting steps specific to PDF and Windows 365.
    These paths connect directly to Microsoft support agents (chat or call back) who can work live through the Windows 365 and PDF problem.
