My inbox has now been split into Focus and Other.
Marie McAllaster 20 Reputation points
2026-06-16T15:51:50.8766667+00:00
The other being archive. I went into settings and removed the split from focus and other. However my email is still showing under Focus and Archive? How do I fix this?
Marcin Policht 109.5K Reputation points MVP Volunteer Moderator
2026-06-16T16:25:22.6266667+00:00
Refer to https://support.microsoft.com/en-us/office/focused-inbox-for-outlook-f445ad7f-02f4-4294-a82e-71d8964e3978
Focused Inbox separates your inbox into two tabs—Focused and Other. Your most important email messages are on the Focused tab while the rest remain easily accessible—but out of the way—on the Other tab.
To create an inbox that "feels right" to you, the system takes into account emails and contacts with whom you interact, and filters out noisy sources like automatically generated or bulk email. The more you use it, the better it gets.
Select the version that corresponds to the one you are using and follow directions to configure it
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
0 additional answers
