Error code 0x80004005 in Windows Media Player is commonly associated with missing, outdated, or incompatible codecs needed to play the video.
Try these steps:
- Enable automatic codec download in Windows Media Player
- Open Windows Media Player.
- On the Tools menu, select Options.
- Go to the Player tab.
- Select Download codecs automatically and select OK.
- Try playing the video again. If prompted to install a codec, select Install.
- Check which codec the file needs
- In Windows Media Player, start to play the file (or select it in the Now Playing list).
- In the Now Playing area, right‑click the file and select Properties.
- On the File tab, note the Audio codec and Video codec entries.
- On the Help menu, select About Windows Media Player, then select Technical Support Information.
- In the browser page that opens, scroll to Audio Codecs and Video Codecs and check whether the codec from step 3 is listed.
- If the codec is missing or shows problems, reinstall or update that codec if possible, then try the file again.
- Use Web Help to locate the codec
- Try playing the file again.
- When the error appears, select Web Help.
- On the Microsoft web page, follow the link to the Wmplugins site.
- Follow the instructions there to download and install the required codec.
- Install a codec pack (Windows 10/11)
If the error appears only with certain file types, install or update a codec pack that includes the needed codecs:
- Check the file’s codec: right‑click the media file in File Explorer → Properties → Details tab.
- Install a reputable codec pack such as K‑Lite Codec Pack or Combined Community Codec Pack (CCCP) that supports that codec.
- Try playing the file again in Windows Media Player.
- If only one specific file fails If other files of the same type play correctly, the file may be corrupted or use a codec that Windows Media Player does not support. In that case, a third‑party codec or player that supports that format may be required.
If none of the above works for any video file, there may be a broader playback issue (for example, DirectX or display driver problems), and updating display drivers or DirectX may be necessary.
- You receive a codec error message, or audio plays but video doesn't play when you play media files in Windows Media Player 11
- Basics about videos and video codecs in Windows Media Player
- Troubleshoot Windows Media Player Errors
- How to troubleshoot playback in Windows Media Player 9
- You receive an error message when you try to play an .avi file in Windows Media Player
