Cant move an MCPP purchase Virtual Machine and associated items to Azure Sponsorhip
Chadha Harpaul 40 Reputation points
2026-06-11T05:43:06.7933333+00:00
I am trying to move an MCPP purchase VM and associated Network/Disk etc to the Azure Sponsorship but I am unable to select Azure Sponsorship. What can I do here?
Cost Management
Cost Management
A Microsoft offering that enables tracking of cloud usage and expenditures for Azure and other cloud providers.
Lakshma Reddy Vattijonnala 1,660 Reputation points Microsoft External Staff Moderator
2026-06-11T11:22:23.9866667+00:00
Hi @Chadha Harpaul
Thank you for the details. Since the move is failing at the validation stage it indicates that Azure has already evaluated the request and identified a blocking constraint in the resource configuration or dependencies.
Why validation is failing:
During a cross-subscription move, Azure performs strict validation checks before allowing the operation. A failure at this stage typically means one of the following:
  • One or more resources in the move set are not supported for cross-subscription moves
  • Dependencies are incomplete (not all related resources included in the move)
  • There are hidden constraints (for example, SKU limitations, regional restrictions, or service-specific limitations)
  • Resource configuration is not compatible with the target subscription
Azure will block the move entirely if any dependency fails validation.
This article explains how to move Azure resources between resource groups within the same subscription or across different subscriptions Move Azure resources to a new resource group or subscription - Azure Resource Manager | Microsoft L…
Recommended next steps:
Based on this scenario I recommend the following approach:
  1. Review the exact validation error
    • The error message usually identifies the specific resource causing the failure
    • This is key to determining whether it’s a support limitation or a dependency issue
  2. Validate all dependencies are included Ensure the move operation includes all related components together, such as:
    • Virtual Machine
    • Managed disks
    • Network interfaces (NICs)
    • Public IP addresses
    • Network Security Groups (NSGs)
    • Availability sets / proximity placement groups (if applicable)
  3. Check resource move support
    • Even if a VM is supported, attached resources may not be
    • Cross-check each resource type against the supported list above
  4. Test using Azure CLI (optional):
  • az resource move
  • -- ids <resource-id-list> \
  • -- destination-group <target-rg-name> \
  • -- destination-subscription-id <subscription-id>
This helps confirm whether the issue is consistently validation related (not just portal UI)
Important clarification on Sponsorship subscriptions:
Azure Sponsorship subscriptions can have specific constraints, but a validation failure itself is not caused solely by the subscription type.
In most cases, the root cause is:
  • Unsupported resource(s)
  • Missing dependencies in the move set
  • Configuration incompatibility
If validation continues to fail and the error persists after validating dependencies and supported resources, the recommended and most reliable approach is:
  • Recreate the VM in the target (Sponsorship) subscription
  • Move or copy the underlying disks/data
  • Reconfigure networking (NICs, IPs, NSGs) in the target environment
This approach avoids platform level move limitations and is commonly used when validation constraints cannot be resolved.
If you found the answer useful, you can click "upvote". If you have further questions regarding this answer, feel free to click "Comment". This helps the community by allowing others with similar queries to easily find the solution.
0 additional answers
