OFFLINE PRINTER
Angela Deschene 20 Reputation points
2026-06-11T02:56:17.63+00:00
PRINTER IS ALWAYS SAYING ITS OFFLINE, IF I RUN THE TROUBLESHOOTER, IT USUALLY FIXES IT THEN PRINTS, BUT THIS TIME IT DIDN'T WORK. THIS JUST STARTED DON'T KNOW WHY. NOTHING HAS CHANGED EXCEPT ADDED A SECOND PRINTER
HOW CAN I FIX IT SO IT PRINTS WHEN I NEED IT TO?
Jeronimo Fuerte 46,305 Reputation points Independent Advisor
2026-06-11T03:53:46.1833333+00:00
Hi! Please remove and reinstall only the affected printer from Settings > Bluetooth & devices > Printers & scanners > Remove, then add it again using Add device.
Since this started after adding a second printer, first make sure Windows is not sending the job to the wrong printer.
  1. Go to Settings > Bluetooth & devices > Printers & scanners.
  2. Select the printer you want to use and click Set as default. If you do not see that option, turn off Let Windows manage my default printer first.
0 additional answers
