I need aka.ms/recovery key
Mary Reese 5 Reputation points
2026-06-10T19:48:25.66+00:00
I do not know how to get this . But my computer keeps asking for this number. The computer locks on blue site that ask for this number. I am old I do not know what this is or how to fix this problem???
Windows for home | Windows 11 | Recovery and backup
  1. Estrella721 46,015 Reputation points Independent Advisor
    2026-06-10T20:23:48.9566667+00:00
    Do you mean the Bitlocker Recovery Key?
    Usually, the BitLocker recovery key is stored in the Microsoft account used to set up your computer. You can log in using the link below to check if it is available:
    https://account.microsoft.com/devices/recoverykey
    Just in case there's a work or school account linked to your device, it may have been set up using that account
    https://aka.ms/aadrecoverykey
  2. Lucus-V 13,115 Reputation points Microsoft External Staff Moderator
    2026-06-15T19:14:11.7366667+00:00
    Hi Mary Reese,
    BitLocker is a Windows security feature that protects your data by encrypting your drives. This encryption ensures that if someone tries to access a disk offline, they won’t be able to read any of its content. More information can be found on BitLocker overview.
    Please visit Find your BitLocker recovery key for more information about finding your BitLocker recovery key. Additionally, you might have a backup on a file on an unencrypted partition, external drive, or cloud drive.
    You can visit the page or aka.ms/recoverykey on another device then sign-in with your account to view BitLocker recovery key then enter it to your computer. Please kindly check for BitLocker recovery key on all accounts that you have.
    If you forget your BitLocker password and cannot find BitLocker recovery key, then no one even Microsoft can unlock your drive or restore BitLocker keys. It's how BitLocker was designed to protect your data.
    I hope that above information is helpful to you.
