How to fix this issue, cant log into my hotmail account.
Naveed 0 Reputation points
2026-06-09T11:52:18.62+00:00
UTC Date: 2026-06-09T11:27:45.818Z
Client Id: 118E68102F524EF68A0828FDBD1D8FE4
Session Id: 0f76eb81-82fa-4358-a309-31af006c87e9
Client Version: 20260522011.09
BootResult: cdnError
Failed resource: https://res-1.cdn.office.net/owamail/hashed-v1/msalv5/resources/locale-consolidated/en/owa.consolidated.mail.runtime.m.77201d72.json?bO=1
Back Filled Errors: Uncaught Error: Failed to load localized strings
    at f (https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.worker.7868.306da939.js:1:132536)
    at u (https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.worker.7868.306da939.js:1:132313):undefined|Unhandled Rejection: ChunkLoadError: Loading chunk 44636 failed.
(error: https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.44636.m.993721bd.js):undefined|Unhandled Rejection: ChunkLoadError: Loading chunk 29124 failed.
(error: https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.29124.m.a6cb9aa9.js):undefined|Unhandled Rejection: ChunkLoadError: Loading chunk 29124 failed.
(error: https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.29124.m.a6cb9aa9.js):undefined|Unhandled Rejection: ChunkLoadError: Loading chunk 86169 failed.
(error: https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.86169.m.6d58adae.js):undefined|Unhandled Rejection: ChunkLoadError: Loading chunk 86169 failed.
(error: https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.86169.m.6d58adae.js):undefined|Unhandled Rejection: ChunkLoadError: Loading chunk 54044 failed.
(error: https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.54044.m.118ae40b.js):undefined|Unhandled Rejection: ChunkLoadError: Loading chunk 54044 failed.
(error: https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.54044.m.118ae40b.js):undefined|undefined:undefined|undefined:undefined|undefined:undefined|undefined:undefined|undefined:undefined|undefined:undefined|undefined:undefined|undefined:undefined|undefined:undefined|undefined:undefined
err: Error: Failed to load localized strings
esrc: InitLoc
et: ClientError
estack: Error: Failed to load localized strings
    at d (https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.mailindex.3510ebc1.js:1:125178)
    at f (https://res.public.onecdn.static.microsoft/owamail/hashed-v1/msalv5/scripts/owa.mailindex.3510ebc1.js:1:124955)
    2026-06-09T11:52:37.5033333+00:00
    The error log shows Outlook on the web (Outlook.com/Hotmail) failing to load its scripts and localized strings from the content delivery network (CDN). This is a client-side loading issue, not a password or account-block problem.
    Use these steps to troubleshoot and regain access:
    1. Verify Outlook.com service status
    • If Outlook.com has a service issue, sign-in or loading can fail even with correct credentials.
    • Check the service status using the Outlook.com help page, then try again when status is normal.
    1. Try a different browser or InPrivate/Incognito window
    • Open a different browser (for example, Edge or Chrome) and go to Outlook.com.
    • Or in the same browser, open an InPrivate/Incognito window and sign in again.
    • If it works there, the issue is likely cached data or an extension in the original browser.
    1. Clear browser cache and disable extensions
    • Clear the browser cache and cookies.
    • Temporarily disable browser extensions such as ad blockers, VPN extensions, or security add-ons.
    • Close and reopen the browser, then try signing in again.
    1. Check network and security software
    • If all devices on the same network fail in the same way, a firewall, router, or DNS setting may be blocking or rewriting CDN traffic.
    • Try another network (for example, mobile hotspot) to see if Outlook.com loads correctly.
    • If it works on another network, review router/firewall content filters or DNS filtering services that might block Microsoft CDN domains.
    1. Use the Outlook.com sign-in troubleshooter
    • If sign-in itself is failing (not just loading the mailbox UI), use the sign-in troubleshooter linked from the Outlook.com help page to diagnose and fix common sign-in problems.
    1. If the account itself is blocked or old
    • If the account is reported as blocked, follow the “Unblock my Outlook.com account” guidance from the Outlook.com help.
    • If the account has not been used for more than two years, it may have been deleted and cannot be recovered.
    If none of the above resolves the issue and other accounts or sites work normally, contact Microsoft Support from the Outlook.com help page and provide the error details and logs.
