how to turn off my pin and use a password
Steven Taylor 20 Reputation points
2026-06-08T11:50:13.6666667+00:00
how to turn off my pin and use a password as there is no option on my windows 11 pc to do this
Windows for home | Windows 11 | Accounts, profiles, and login
EmilyS726 269.5K Reputation points Independent Advisor
2026-06-08T12:40:16.8566667+00:00
The AI answer gave the instruction in the wrong order.
First, go to Settings > Accounts > Sign in options, scroll down to mid page, under "Additional Settings",Make sure "For improved security, only allow Windows Hello Sign-in for Microsoft accounts on this device (Recommended). " is turned OFF.
Then, you might want to close this page, reopen this page to find the pin removal option.
If for any reason you still cannot get this removed, Can you go to your Windows Settings > Accounts > Access Work or School (note, it is the briefcase icon, not the little person icon). Then see if the organization email address is still listed? If so, click on it and then disconnect it. Restart the computer and try again.
0 additional answers
