how to fix the problem of my packages saying and unliceced and turning off
Barack Ochola 0 Reputation points
2026-06-03T10:53:23.1266667+00:00
packages what to be repaired daily and tun offUser's image
    2026-06-03T10:53:45.91+00:00
    The screenshot shows Word reporting an error and your Office apps showing as Unlicensed Product. Use these steps to fix both the crash and the unlicensed state.
    1. Run a full Online Repair of Office
      1. Open the Windows Settings app (gear icon on Start).
      2. Go to Apps > Apps & features.
      3. Find Microsoft Office or Microsoft 365 in the list and select it.
      4. Choose Modify > select Online Repair (not just Quick Repair) and run it.
      5. When it finishes, restart Windows and try Word again.
      This repairs damaged Office files that cause the “Word has run into an error” message.
    2. Make sure only one copy of Office is installed
      1. Open Control Panel > Programs and Features.
      2. In the search box, type office.
      3. If more than one Office version appears, right‑click the ones that are not used and select Uninstall.
      4. Restart the computer.
      Multiple versions can cause activation to fail and show as Unlicensed Product.
    3. Sign in with the correct account to activate
      1. Open Word or another Office app.
      2. If prompted to sign in, use the same Microsoft account that was used to buy or redeem Office.
      3. If a message appears saying no Office products are found for that account, sign out and try any other Microsoft account that might be associated with the purchase.
    4. If apps still show Unlicensed Product
      1. Confirm that the Microsoft 365 or Office subscription is still active (for subscription products).
      2. If activation still fails after Online Repair and correct sign‑in, contact Office support for further activation help.
    If the in‑app “Repair Now” button does not fix the crash, the full Online Repair and, if needed, a complete uninstall and reinstall from the Microsoft account page are the recommended next steps.
