OneDrive - all kinds of issues
MichaelT 5 Reputation points
2026-06-02T14:27:58.0866667+00:00
What is up with OneDrive? Here are known issues:
  1. Backup on Android doesn't always work unless you launch the app or worse turn on/off backup
  2. Images are added in random order, not chronological. I had an image from May 1st appear ahead of June 1st.
  3. The search online by filename is completely broken for months now and returns the wrong files.
  4. The date scroll feature gets stuck at a particular date.
I guess the question is:
Does Microsoft have a single developer working on OneDrive and do they know how to write code?
It's absurd because my photos may as well start disappearing or appearing on other people's accounts at this point.
Get your act together!!! Hire folks from Google drive and pay 2 million a year if you need to. This is billion in profit every year.P.S. Your answers even crashed so please replace every developer there too. Also after generating 5 tags, it kept asking for tag is required. Unbelievable! Fire Natella today.
Microsoft 365 and Office | OneDrive | For home | Android
    2026-06-02T14:28:26.8166667+00:00
    For each of the described behaviors, there are documented limitations or workarounds rather than a single root cause.
    1. Backup on Android only working when the app is launched
    On Android and iOS, camera upload and sync are not fully autonomous background services. Several conditions must be met:
    • The OneDrive app must be running; swiping it away can stop automatic backups.
    • Location Services should be enabled, because changes in location are used to trigger background activity.
    • Some device settings or data plans only allow certain features over Wi‑Fi.
    Recommended checks:
    1. Open OneDrive > tap the account image > Settings > Camera backup.
    2. Confirm the correct Camera backup account is selected.
    3. If not on Wi‑Fi, ensure Data usage (or similar) allows backup over mobile network.
    4. Ensure Backup only when charging is not selected if immediate backup is expected.
    5. Keep the OneDrive app open periodically to force synchronization.
    6. On some Android devices, ensure OneDrive is allowed to run in the background (for example via Settings > Battery > Battery Usage > OneDrive > Launch options > Manage Manually > Run in background).
    These are platform and app constraints rather than a sign that files will appear in other accounts; uploads are tied to the signed‑in account.
    1. Photos appearing in unexpected order
    When camera upload “takes too long to set up or look for photos” or there are many photos, uploads can be delayed and processed in batches. This can result in:
    • Photos uploading out of strict capture-time order.
    • Apparent “random” ordering while the service indexes or finishes upload.
    Contributing factors:
    • Very large camera rolls.
    • Inclusion of facial recognition and location data, which can slow processing.
    • Network connections that prioritize downloads over uploads.
    Mitigations:
    1. Reduce the number of photos in the device camera roll by moving some to other folders.
    2. Leave OneDrive running (ideally overnight) to complete uploads.
    3. Avoid repeatedly signing out or reinstalling the app, as that restarts scanning and upload.
    4. Search by filename returning wrong files
    The provided context does not document a specific bug with filename search returning incorrect items, but it does note that if storage is exceeded or sync is incomplete, not all files will upload or index correctly. If camera roll or other content is not fully uploaded, search results may not match expectations because:
    • Some files are not yet in OneDrive.
    • Some files are partially uploaded or blocked by storage limits.
    Checks:
    1. Confirm that Microsoft storage is not exceeded; if it is, new files (including camera roll) will not upload or sync. See Microsoft storage quotas.
    2. Verify that camera upload has completed (no long-running “setting up” state).
    3. If issues persist after confirming upload and storage, use the official troubleshooting path for mobile app problems and, if needed, raise a support ticket from there.
    4. Date scroll or timeline issues
    The context describes that camera uploads can “take too long to set up or look for photos” especially with large libraries, facial recognition, and location data. During this period, views that rely on date-based indexing (such as date scroll/timeline) can behave inconsistently or appear stuck until indexing completes.
    Workarounds:
    1. Let OneDrive complete upload and indexing by leaving the app running for an extended period.
    2. Reduce the number of photos in the camera roll.
    3. Ensure the device is on a stable network and not in a low-power mode that restricts background activity.
    4. Reliability and data safety
    The documented behaviors—needing the app open, slower uploads with large libraries, and delays when storage is full—do not imply that photos will “start disappearing” or “appearing on other people’s accounts.” Files are associated with the signed‑in Microsoft account, and when removed from OneDrive they go to the OneDrive Recycle Bin for up to 30 days, where they can be restored.
    For better control and space management:
    • Consider whether every image in the Android camera roll needs to be backed up.
    • Periodically clean up backed‑up photos using the OneDrive.com photo viewer instead of only managing from the mobile camera roll.
    If the documented troubleshooting steps do not resolve the issues, the next supported step is to follow the “Troubleshoot OneDrive mobile app problems” guidance and escalate through official support so logs and account-specific details can be reviewed.
