Thank you, to close this thread, you may press Yes below the most helpful post. Have a great day!
How to fix a trackpad that freezes for a few seconds repeatedly on a new msi laptop?
Hi i have a new msi laptop , the trackpad freezes for a few seconds repeatedly pointer on screen cant be moved then works again.
I have downloaded trackpad drivers and windows updates.
Thanks.
From Rob.
Alright. Please contact MSI as during the warranty, they are responsible for full functioning of the device.
I hope this information helps. If you have any more questions, don't hesitate to reach out.
Otherwise, if your problem is resolved, please take a moment to rate the answer. Wishing you good luck!
6 additional answers
SD - IA 180.3K Reputation points Independent Advisor
2026-05-30T12:23:57.1233333+00:00 Also when i first set the laptop up when i got it , the trackpad on bottom left of it was very hard to press compared to the right side bottom which was fine to press.
Thank you, yes this means there is a hardware defect within the trackpad. Is the laptop under warranty?
Caleb Asiago: 780250 0 Reputation points
2026-05-30T12:31:13.0066667+00:00 1.Update or reinstall the trackpad driver
Go to Device Manager → Mice and other pointing devices → right-click your trackpad → Update driver. Alternatively, download the latest driver from MSI's official support site for your exact model.
- Disable "Palm Check" or sensitivity settings
Go to Settings → Bluetooth & devices → Touchpad and reduce palm rejection sensitivity — it may be misreading your palm as input and pausing.
- Check for driver conflicts
If you have a mouse plugged in, Windows sometimes disables the trackpad intermittently. Go to Touchpad settings and make sure "Leave touchpad on when a mouse is connected" is enabled.
- Disable the "HID-compliant mouse" duplicate
In Device Manager, you may see two trackpad/mouse entries. Disabling the extra HID-compliant device sometimes resolves
2026-06-01T14:23:40.08+00:00 Any other assistance I can provide, Rob?
