It's not going to the next page.
대치노인복지관 0 Reputation points
2026-05-27T04:06:54.8366667+00:00
The billing profile continuously shows 'loading' and is unselectable, causing the 'Use' button at the bottom to be grayed out. It remains stuck on loading and won't progress.User's image
    2026-05-27T04:07:09.2433333+00:00
    This behavior is typically caused by the browser blocking cookies or other site data that the billing page needs to finish loading.
    Try these steps in order:
    1. Allow cookies and third‑party cookies
      • In the browser settings, make sure cookies are allowed and that third‑party cookies aren’t blocked.
      • If there’s any tracking‑protection or anti‑tracking extension, temporarily disable it for the Microsoft billing/Azure site.
    2. Enable pop‑ups for the site
      • If the browser shows a “pop‑up blocked” icon in the address bar, allow pop‑ups for the Microsoft billing/Azure domain and reload the page.
    3. Clear cache and cookies for the site
      • Clear browsing data (at least cookies and cached images/files) and then sign in again to the Microsoft 365/Azure portal and retry the billing profile step.
    4. Use an InPrivate/Incognito window
      • Open a new InPrivate/Incognito window and repeat the billing profile/credit usage flow there. This bypasses cached data and many extensions and often lets the page load correctly.
    5. Try another browser or device
      • If it still hangs on “loading”, try a different browser (for example, Edge instead of Chrome) or another device to complete the billing profile.
    If none of these steps work, contact Microsoft support from another browser/session and provide a screenshot plus the time and region; support can check for a backend issue with the billing experience.
