hi I have lost all sound and need to down load audio service, but have no idea how to do it, can you help me please
fredy 0 Reputation points
2026-05-26T16:16:50.2933333+00:00
hi  I have lost all sound and need to down load audio service, but have no idea how to do it, can you help me please #laptop
    2026-05-27T03:56:18.1566667+00:00
    Hi fredy,
    I understand how frustrating it is to suddenly lose sound.
    Have you already tried the Q&A Assist suggestions? In addition, could you confirm:
    • Your exact Windows version (7, 8, or XP)
    • Whether you see any message like “Audio service is not running”
    In the meantime, please try restarting the Windows Audio service:
    This directly fixes cases where the service has stopped or didn’t start properly.
    1. Press Windows + R
    2. Type services.msc > press Enter
    3. Find “Windows Audio” in the list
    4. Right‑click it > choose “Restart”
    5. Then double‑click it and make sure:
      • “Startup type” = Automatic
    Restarting this service can restore sound if it failed to start correctly.
    If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
    Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
  2. AI answer
    2026-05-26T16:17:11.6133333+00:00
    Follow these steps on the laptop to restore sound; they reinstall or repair the audio “service” (driver and services) without needing a manual download.
    1. Check output device and volume
    • Select the Speakers icon on the taskbar.
    • Click the arrow next to the volume slider and make sure the correct speakers/headphones are selected.
    • Make sure volume is turned up and not muted.
    1. Run the Windows audio troubleshooter
    1. Verify cables and hardware
    • If using external speakers/headphones, make sure they are firmly plugged in and powered on.
    • Try unplugging headphones to see if the built‑in speakers start working.
    1. Update the audio driver
    • Press the Windows key, type device manager, and open it.
    • Expand Sound, video and game controllers.
    • Right‑click the audio device (for example, Realtek or similar) and select Update driver.
    • Choose Search automatically for updated driver software and complete the wizard.
    1. Reinstall the audio driver If updating does not help:
    • In Device Manager, under Sound, video and game controllers, right‑click the audio device and select Uninstall device.
    • Check Delete the driver software for this device if available, then select Uninstall.
    • Restart the PC (Start > Power > Restart). Windows will reinstall a driver automatically.
    1. Use the generic Windows audio driver (Windows 10) If sound still does not work:
    • Open Device Manager.
    • Right‑click the audio device and select Update driver.
    • Select Browse my computer for drivers > Let me pick from a list of device drivers on my computer.
    • Select High Definition Audio Device and click Next.
    1. Check Windows Update
    • Go to Start > Settings > Update & Security > Windows Update > Check for updates.
    • Install any available updates and restart the PC.
    If after these steps there is still no sound and Windows shows “No audio device is installed,” or there is no activity in Device Manager under Sound, video and game controllers, install the latest audio driver from the laptop manufacturer’s support site or contact the device manufacturer for hardware diagnostics.
