Samsung sd card not backing up.
A C 0 Reputation points
2026-05-25T16:04:28.2033333+00:00
I've just realised that the SD card (where my photos are stored) on my Samsung A53, android version 16, has not backed up since 31 March 2026.
I've tried the 'Back up now' option, the option goes grey for a while, then blue again, but nothing changes. They're not in onedrive from my phone or PC. They are visible in Samsung gallery.
WhatsApp Image 2026-05-25 at 17.45.25
The folders to backup do not match the folder names from Samsung files, but I've tried selecting them all, no progress. The photos are in /SD card/DCIM/Camera
Thanks in hope.
Microsoft 365 and Office | OneDrive | For home | Android
2026-06-07T14:24:34.54+00:00
Hi All,
The eventual fix, for now anyway, was very simple, should have thought to try it.
In Onedrive Profile > Settings > Gallery Sync > toggle the sync off, leave for a few minutes, then on again. Everything just started coming through.
Thanks go to [Moderator Note: Personal Info Removed] S in the OneDrive Team.
PS, Microsoft now also allow you to change the primary email on your account!
2 additional answers
  1. Xavier-D 13,385 Reputation points Microsoft External Staff Moderator
    2026-05-26T02:34:07.1466667+00:00
    Hello A C
    I can see that you are having trouble with backing up your sd card in OneDrive
    Based on what you described, this usually means the OneDrive Android app is not completing the photo backup, even though Back up now briefly starts.
    Camera backup on Android depends on the correct backup account, app permissions, available storage, and the app being allowed to keep running.
    Here are what you can try on OneDrive app to see if it can fix the issue:
    • Go to Profile > Settings > Camera backup and confirm the Camera backup account is the correct Microsoft account, since camera backup only works to one account at a time.
    • In the same menu, check that Back up over Wi‑Fi and mobile network is enabled if needed, and that Backup only when charging is turned off unless you want uploads to run only while plugged in
    • Keep the OneDrive app open for a while and avoid swiping it away from recent apps, because backup may not continue if the app is closed
    • Check that OneDrive still has permission to access all photos and videos and that your OneDrive storage is not full, because either of these can prevent new uploads.
    • Under Camera backup > Back up device folders, make sure the Camera folder is still selected for backup.
    As a workaround, you can manually upload the missing photos from the SD card in the OneDrive Android app by using Add > Upload.
    I hope this information can get the missing photos backed up again soon
    Feel free reply back to this post and update me on your situation, I'll be happy to help.
  2. NeilH 0 Reputation points
    2026-07-06T12:47:45.1666667+00:00
    We finally solved this on out Samsung Galaxy S20 yesterday. After trying clearing cache and deleting data for OneDrive, then "uninstalling" (you can't actually uninstall, but disable and uninstall updates). Then reinstalled. This didn't solve the problem directly. After a bit more searching, Google AI reported that sometimes there have been issues with the Microsoft Account and the link with Samsung (something to do with the service that is being withdrawn). So the actual solution was to go to "Manage Accounts" in Settings. Find all the Microsoft or Microsoft 365 or OneDrive accounts and "Remove Account".
    After this go back to OneDrive, sign in again and within a minute, the Photo Backup started working again!
    I'm not sure if the cache clear and data delete etc was needed, but I've included as this was the complete chain of actions. I suspect it was only the account remove and sign in that was needed, but I've no way to test again now.
    Hope this helps!
