phone link issues; authentication issues;
harv bailey 0 Reputation points
2026-05-22T16:23:02.5333333+00:00
having phone link issues and then authentication issues on iphone; why is everything is difficult? after following instructions and having things appear to work, MS then requires authentification in MS app or authenification app, neither of which are user friendly.
Microsoft Security | Microsoft Authenticator
    2026-05-22T16:23:27.5+00:00
    Several different issues are overlapping here: Phone Link on iPhone, SMS/phone verification, and Microsoft Authenticator-based MFA. Below are concrete steps and what to check.
    1. Phone Link basics on iPhone
    • Phone Link only works with personal iOS accounts, not work/school accounts.
    • Requirements:
      • Windows 10 (May 2019 update or later) or Windows 11
      • PC with Bluetooth Low Energy (BLE)
      • iPhone running iOS 15 or later
    • To pair:
      • On Windows: open Phone Link and follow the pairing instructions.
      • On iPhone: optionally install Link to Windows from the App Store if prompted.
    If Phone Link suddenly stops finding the iPhone or asks to relink, sign out and relink:
    • On iPhone: open Link to WindowsSettingsSign out → confirm.
    • Reopen Link to Windows, sign in with the Microsoft account, and follow the steps to relink to the PC.
    If location permission is requested and blocking features:
    • On iPhone: SettingsAppsLink to WindowsPermissionsLocation → choose:
      • “Allow only while using the app” or
      • “Ask every time”
    1. When sign-in keeps asking for Microsoft Authenticator or “another method” Microsoft accounts often have multiple verification methods: Authenticator app, SMS, phone call, alternate email. Problems usually fall into these categories:
    2.1. Authenticator shows “Authentication did not complete” Check the following on iPhone:
    1. App locked
      • Open Microsoft Authenticator and ensure it is unlocked (enter device PIN/Face ID if prompted).
    2. Notifications
      • Make sure notifications are enabled and not silenced:
        • iOS Settings → Notifications → Microsoft Authenticator → allow notifications.
      • If using SMS codes as backup, check text messages; codes may arrive silently.
    3. App version
      • Ensure the latest Microsoft Authenticator version is installed from the App Store.
    4. Network
      • Make sure the iPhone has internet.
      • If prompts fail, switch between Wi‑Fi and mobile data and try again.
    5. Device date/time
      • iOS Settings → General → Date & Time → enable “Set Automatically”.
    2.2. SMS or phone call verification not arriving or giving errors If SMS or call is used as backup and fails:
    • Try up to five times within 5 minutes; Microsoft rotates between multiple telecom providers.
    • If still failing, an admin or support case is needed.
    • Common causes and checks:
      • Hit rate limits: “You’ve hit our limit on verification calls/texts” → wait a few minutes and use Authenticator or verification code instead.
      • “Sorry, we’re having trouble verifying your account” → may indicate high volume or risk-based blocking on that phone number or method. Use another method (Authenticator, alternate email) or contact admin/support.
      • Wrong phone number or country code → verify the correct number is registered in the account’s security info.
      • Third‑party security apps or carrier filters may block verification SMS/calls → temporarily disable such apps and retry.
      • Call going to voicemail → ensure the phone is on, has signal, and call forwarding/Do Not Disturb are not interfering.
    If a “Try another verification method” or similar block appears:
    • Possible reasons: unusual activity, high volume of requests, or risk-based blocks.
    • To resolve:
      1. Use a different verification method on the account (e.g., alternate email instead of SMS).
      2. Try a different network (switch Wi‑Fi/cellular or use another Wi‑Fi).
      3. Wait: repeated attempts can extend the block; waiting up to 24 hours or longer (up to a week) may be required.
      4. Use the sign‑in helper at the provided Microsoft link when available.
    2.3. When completely locked out because of a new phone If the old phone is gone and Authenticator was the only admin method, and SMS/phone also fail, and this is a business/tenant admin account:
    • Microsoft’s Data Protection team must reset the admin’s MFA.
    • Steps (from similar resolved cases):
      • Call Microsoft global customer service (commercial support) and clearly state:
        • Using Office 365/Microsoft 365 for business.
        • This is a company/education account.
        • Caller is the only administrator and is locked out due to Authenticator on a replaced phone.
      • Ask to create a service request and be routed to the Data Protection team for admin MFA reset.
    • If support is hard to reach, one workaround used successfully:
      • Create a new trial Microsoft 365 tenant.
      • In that new tenant’s admin center, open Support → Help & support and submit a ticket explaining that access is needed to a different, existing tenant where the caller is the locked-out admin.
    1. If access still exists on a PC browser If the account still signs in on a PC browser, use that session to fix MFA before losing access:
    • Go to the Security info / Additional security verification page.
    • Remove old phone entries.
    • Add the new phone number and reconfigure Microsoft Authenticator.
    • If necessary, temporarily disable 2FA (where allowed) to break the deadlock, then re‑enable and re‑enroll the new phone.
    1. If text messages or calls are unreliable For ongoing use:
    • Prefer Microsoft Authenticator over SMS:
      • Works over Wi‑Fi or cellular.
      • Can generate verification codes even with no signal.
    • If SMS is often delayed or missing, switch to Authenticator or phone call as the primary method.
