How to fix this issue
2026-04-29T00:16:05.1033333+00:00
Correlation Id: ff000000-0000-0000-0000-000000000000
Timestamp: 2026-04-29T00:10:37.000Z
DPTI: 82431da830b78899f48c9785c4a4570e9ae91fd747f8035656acac1d83b0c5eb
Message: The credential is invalid. Unexpected sub status (6008).
Tag: 657rx
Code: 2148073494
Microsoft 365 and Office | Microsoft 365 Defender | Other | Windows
    2026-04-29T00:16:19.0466667+00:00
    The error indicates an invalid credential problem. Use the following steps to troubleshoot and fix it:
    1. Verify the username format
      • If signing into a Microsoft Entra joined or hybrid-joined Windows device or service, use ******@domain.com format.
      • If signing into a domain-only joined machine, use DOMAIN\user format.
      • To confirm the device join state on the target Windows machine, run in an elevated Command Prompt:
        • dsregcmd /status
        • In the Device State section:
          • AzureAdJoined : YES → use ******@domain.com.
          • AzureAdJoined : NO and DomainJoined : YES → use DOMAIN\user.
    2. Confirm the password and account status
      • Make sure the password is correct and not expired.
      • Ensure the account isn’t locked out or disabled.
      • If possible, change the password and try again.
    3. Check for account restriction policies
      • Some accounts have restrictions such as:
        • Time-of-day login restrictions.
        • Restrictions on which workstations the account can log on from.
      • Ask the directory or security administrator to verify that no such policies are blocking sign-in for this account from this device.
    4. Test the same credentials directly on the target machine
      • Sign in locally or via Remote Desktop to the same machine or service using exactly the same username and password that trigger this error.
      • If sign-in fails there as well, use the on-screen error to further pinpoint whether it’s:
        • Wrong username format.
        • Password issue.
        • Account restriction (logon hours, workstation restriction, etc.).
    5. If using Power Automate desktop flows or similar automation
      • Recreate or edit the connection and re-enter the credentials with the correct format.
      • Ensure the account used for the connection can sign in interactively to the target machine without errors.
    If, after these checks, the credentials still fail but work elsewhere, contact the tenant or system administrator with the correlation ID, timestamp, and error code so they can review sign-in logs and policy configuration.
  2. Manoel Barros 21,735 Reputation points Independent Advisor
    2026-04-29T01:44:03.7566667+00:00
    Hi!
    Are you experiencing this error when logging into Outlook, or any Microsoft website, in your browser? Or in a Windows app, such as the Microsoft Store or Microsoft 365?
    Please provide more details.
    If you are trying to log in through a browser
    If you are trying to log in through Windows or an installed app
    • Check if your device is blocked: https://account.microsoft.com/devices > Your computer should appear in the list.
    • If you're trying to sign in to an app, such as the Microsoft Store or Office, first try signing in to Windows in Settings > Accounts.
    • See if you can sign in to a new user. Go to Settings > Accounts > Other Users > Add account > I don't have this person's sign-in information > Add a user without a Microsoft account > Fill in the fields > When creating a new user, try adding the account in the settings.
  3. NOMBEKO KWENZEKA SHABANGU 0 Reputation points
    2026-08-12T15:25:38.3466667+00:00
    Recomended
  4. safe management 0 Reputation points
    2026-08-26T18:07:06.1233333+00:00
    How Log in Microsoft Account
