sound system
Jayhar Solaiman 0 Reputation points
2026-04-27T16:05:42.1733333+00:00
i cannot connect my speaker to my laptop (it's with wire) i tried a different speaker but it's stil cannot
Surface | Surface Laptop | Sound and camera
  1. Clary-N 15,735 Reputation points Microsoft External Staff Moderator
    2026-04-28T00:52:35.4466667+00:00
    Hi Jayhar Solaiman,
    Please try following the steps already shared by Q&A Assist as they cover the main configuration checks.
    If the issue is still happening, you could try a few additional checks to help narrow down what’s going on:
    • When you plug in the wired speaker, open Control Panel > Sound > Playback and see if a new device appears. If nothing changes at all when inserting the plug, it may indicate the system is not detecting the connection.
    • In the same Playback window, right-click and enable “Show Disabled devices” and “Show Disconnected devices.” Sometimes the wired output is present but hidden and just needs to be enabled.
    • If your device uses Realtek audio, you can also open Realtek Audio Console (if available) and review the connector settings, as detection behavior can sometimes be controlled there.
    For a more thorough refresh, you can reinstall the audio driver from Device Manager:
    1. Right-click Start and select Device Manager
    2. Expand Sound, video and game controllers
    3. Right-click your audio device (for example, Realtek(R) Audio or similar) and select Uninstall device
    4. If you see a checkbox for “Delete the driver software for this device”, leave it unchecked for now, then confirm uninstall
    5. Restart your Surface Laptop
    After restart, Windows will automatically reinstall the audio driver and reinitialize the audio ports, which can help restore jack detection.
    From a troubleshooting perspective, if your built-in speakers still work normally but no wired device is detected at all (even after these checks), it would more likely point to a detection issue with the audio jack rather than the speaker or settings.
    If you’re able to confirm whether anything appears in the Playback list when plugging in the cable, that would help narrow it down further.
    I hope this gives you a bit more to work with. Feel free to share what you find and I'll happy to assist further.
    If you have additional questions about this answer, please click "Comment".
    Note: If you want to receive email notifications about this thread, follow the steps in our documentation to enable email notifications.
  2. AI answer
    2026-04-27T16:05:53.93+00:00
    Try these steps on the Surface Laptop to get the wired speakers working:
    1. Select the correct output device
      • Right-click the speaker icon on the taskbar and select Sound settings.
      • Under Output > Choose where to play sound, open the list and select the wired speakers (or the 3.5 mm device) instead of the built‑in speakers or any Bluetooth/HDMI device.
    2. Check the physical connection
      • Make sure the speaker plug is fully inserted into the Surface Laptop’s 3.5 mm audio jack (push until it clicks).
      • If using an adapter or extension cable, try plugging the speaker directly into the laptop.
      • If possible, try a different cable between the speaker and the laptop.
    3. Reconnect accessories and apps
      • Close any apps playing sound (browser, music, games).
      • Unplug the speaker cable from both the Surface and the speaker, then plug it back in firmly.
      • If the Surface is on a dock, disconnect the dock, then reconnect it and the speakers.
    4. Check for conflicts with other devices
      • If Bluetooth speakers/headphones are paired, temporarily turn Bluetooth off and test again.
      • If using a Surface Dock or external monitor, make sure the monitor or dock is not selected as the default output in Sound settings.
    If the Surface’s built‑in speakers work but no sound comes from any wired speaker after these steps, the issue is likely with the jack/cable path; if no device appears in Output when plugging in the speakers, audio drivers or hardware may need service.
