How to fix multiplayer
Matvii Tomko 0 Reputation points
2026-04-26T03:53:03.86+00:00
so i cant play multi player while i multiplayer is anabled i am a child and i have a family and me and my mom tryed to fix it but we dont know hot to fix our issue
Microsoft 365 and Office | Microsoft Family Safety | For home | Other
    2026-04-26T03:53:14.8866667+00:00
    Multiplayer issues on a child account are usually caused by family/child permissions, even if multiplayer “looks” enabled. A parent or family organizer must change the settings on the organizer account; the child account itself often cannot change them.
    Use these steps on the parent/organizer account (not on the child account):
    1. Go to the Microsoft family/child management page
      • Sign in as the parent/organizer.
      • Open the child’s profile/settings.
    2. Allow multiplayer and third‑party apps
      • Make sure options like “You can join multiplayer games / Play games with others in Xbox multiplayer” are set to Allow for the child.
      • Also ensure access to apps and games that are not published by Microsoft is enabled:
        • Sign in as a parent at https://account.live.com/mk.
        • Select the child.
        • Choose Manage this child's access to third party apps.
        • Select Enable access.
    3. If the child still sees it blocked
      • Changes can take time to propagate. In one reported case, it took over 24 hours after the organizer changed “You can join multiplayer games” to Allow before the child account could play online.
      • Sign the child out of all devices, then sign back in after some time and test multiplayer again.
    If multiplayer is still blocked after the parent has set all relevant options to Allow and waited for the changes to apply, the parent should review all family safety and privacy settings again or contact support for further help.
