How to fix 25H2 problem on Surface Pro 7
Ted 20 Reputation points
2026-04-06T12:52:24.3166667+00:00
25H2 update disabled access to the Internet and NAS. Tried resetting by creating a USB GTP partition boot drive but Surface doesn't recognize it. Now what?
AI answer
2026-04-06T12:52:35.1833333+00:00
To recover the Surface Pro 7 and fix the 25H2 issue, first focus on getting a working USB recovery drive that the device can boot from, then use it to reset Windows.
  1. Recreate the USB recovery drive correctly
    • Use a USB drive that is at least 16 GB.
    • On a working Windows PC, download the correct Surface recovery image for Surface Pro 7 from the Surface recovery site (as described in the referenced Q&A) and follow the instructions in Creating and using a USB recovery drive for Surface.
    • If the USB was prepared manually and the Surface does not recognize it, ensure it is formatted as FAT32 and made bootable:
      1. Insert the USB drive.
      2. Open Command Prompt as administrator.
      3. Run diskpart.
      4. Run list disk and identify the USB disk number.
      5. Run select disk X (replace X with the USB disk number).
      6. Run clean (this erases the USB).
      7. Run create part pri.
      8. Run select part 1.
      9. Run format fs=fat32 quick.
      10. Run active.
      11. Run exit.
      12. Copy the Surface recovery image contents to the root of the USB drive.
  2. Make sure Surface can boot from USB
    • Enter Surface UEFI and verify:
      • Enable Boot from USB devices is On under Advanced options of the UEFI Boot configuration screen.
      • If a boot order is configured, Enable alternate boot sequence is On.
    • If a Windows Insider build was previously installed, toggle Secure Boot: turn it Off, save and exit, then turn it On again so the USB boot drive is recognized.
    • If the USB still does not boot, try another USB drive.
  3. Boot from the recovery drive and reset Windows
    • Boot the Surface from the working USB recovery drive (see Boot Surface from a USB device for details).
    • When the recovery environment starts:
      1. Choose the language.
      2. Choose the keyboard layout.
      3. On Choose an option, select Troubleshoot.
      4. Select Reset your PC.
      5. On Reset your PC:
        • Select Next.
        • Select Yes, repartition the drives.
        • Choose Just remove my files (faster) or Fully clean the drive (more thorough).
        • Select Reset.
    • This will reinstall Windows on the Surface Pro 7 and should restore network and NAS access if the issue was caused by the 25H2 update.
  4. After reset
    • Let Windows Update run until no more updates are available.
    • Test Internet and NAS access before reinstalling additional software.
If the USB drive used for recovery was larger than 32 GB and is now stuck with a 32 GB RECOVERY partition, delete that partition and recreate a full-size volume using Disks & volumes or Disk Management as described in the references.
1 additional answer
  1. Ted 20 Reputation points
    2026-04-06T13:08:43.9533333+00:00
    USB boot locks up at the keyboard layout. How to proceed.
