Authenticator app problem
Riley Helm 0 Reputation points
2026-04-06T01:26:23.3066667+00:00
I can’t get into my Authenticator app but when I try to log in it gives me a number on the app to type into the app( endless loop)
Microsoft Security | Microsoft Authenticator
    2026-04-06T01:26:33.4266667+00:00
    This loop happens when Microsoft Authenticator is the only verification method and sign-in keeps asking for approval in the app that cannot be accessed.
    Use one of these supported paths based on the type of account:
    1. Work or school account (Microsoft Entra / Microsoft 365)
    • If there is another sign-in method configured (SMS, alternate email, hardware token), choose “I don’t have my Microsoft Authenticator app” and then select that alternative method to complete sign-in.
    • If alternative methods also fail and there are multiple admins in the organization, ask a Global Admin/IT admin to:
      1. Go to Microsoft Entra admin center → Users → All users → [your account] → Authentication methods.
      2. Select Require re-register multifactor authentication so MFA methods can be set up again on the new device.
    • If this is a business account and there is no other admin (you are the only admin), contact Microsoft support so the Data Protection team can verify identity and reset MFA for the tenant. Use the regional Customer service phone numbers and follow the IVR path for Office 365 business admin locked out of account, as described in the Q&A guidance.
    1. Personal Microsoft account (Outlook.com, Hotmail, etc.)
    • If another MFA method is configured (SMS, alternate email), select “I don’t have my Microsoft Authenticator app” and use that method.
    • If sign-in is blocked after many attempts, wait and try again later or use a different MFA method as described in the two-step verification guidance.
    1. If “Authentication did not complete” or similar errors appear Check the following on the phone where Authenticator is installed:
    2. Ensure the Microsoft Authenticator app is unlocked (no app lock or screen lock blocking prompts).
    3. Make sure notifications are enabled and not silent for Authenticator; check for any SMS codes that may have arrived quietly.
    4. Confirm the app is updated to the latest version.
    5. Verify the device has a working internet connection (try switching between Wi‑Fi and mobile data).
    6. Ensure the date and time on the device are set correctly.
    7. If the account password is forgotten, use the official Reset your password flow linked in the documentation.
    If none of the above paths work and there is no alternative MFA method and no admin who can reset MFA, the only remaining option is escalation through Microsoft support (Data Protection team) as outlined in the Q&A articles.
