Still have a issue with my wireless headset disconnecting after connecting...
Donnie Mayfield 70 Reputation points
2026-03-29T15:51:36.3866667+00:00
Wireless headset disconnecting immediately after connecting, one of your troubleshooters tried to fix this issue last night with issue unsolved... Help!!
2026-04-01T05:08:28.5666667+00:00
Hi Donnie Mayfield,
I understand how frustrating it is when a wireless headset disconnects immediately, especially after you’ve already tried multiple troubleshooting steps. Have you already tried the Q&A Assist suggestions? In addition, please try the following.
  1. Open “Control Panel”
  2. Go to “Devices and Printers”
  3. Right‑click your headset > “Properties”
  4. Open the “Services” tab
  5. Uncheck “Hands‑free Telephony”
  6. Select “Apply” > “OK”
  7. Turn the headset off and back on, then reconnect
This disables the hands‑free (call) audio profile and forces Windows to use the standard stereo audio profile instead.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
3 additional answers
    2026-03-29T15:51:48.6033333+00:00
    Follow these steps in order on Windows 11 to address a wireless (Bluetooth) headset that disconnects right after connecting:
    1. Run the Bluetooth troubleshooter
      • Open the Get Help app and run the automated Bluetooth troubleshooter. It will run diagnostics and attempt to fix Bluetooth problems automatically.
      • Use the entry point: Run the troubleshooter in Get Help: ms-contact-support://smc-to-emerald/TroubleshootBluetooth.
    2. Turn Bluetooth off and back on
      • Select Start > Settings > Bluetooth & devices.
      • Turn Bluetooth off, wait about 10 seconds, then turn Bluetooth on again.
      • Try reconnecting the headset.
    3. Remove and re-add the headset
      • Go to Start > Settings > Bluetooth & devices.
      • Find the headset in the list, select More options (… ) > Remove device.
      • Select Add device, choose Bluetooth, then select the headset when it appears and complete pairing.
    4. Check the headset battery and pairing mode
      • Fully charge the headset.
      • Turn it off and back on, then put it explicitly into pairing mode (follow the manufacturer’s instructions).
      • Keep it close to the PC while pairing.
    5. Turn off Battery saver mode (if using a laptop/tablet)
      • Select the Battery icon on the taskbar.
      • If Battery saver is on, turn it off so it does not interfere with Bluetooth connectivity.
    6. Disable Bluetooth power saving in Device Manager
      • Select Start, type Device Manager, and open it.
      • Expand Bluetooth, right‑click the Bluetooth adapter/device, and select Properties.
      • On the Power Management tab, clear Allow the computer to turn off this device to save power.
      • Select OK, then test the headset again.
    7. Restart the Bluetooth Support Service
      • Press Windows key + R, type services.msc, and select OK.
      • Scroll to Bluetooth Support Service, right‑click it, and select Restart.
      • After it restarts, try reconnecting the headset.
    8. Update Bluetooth drivers
      • Expand Bluetooth, right‑click the Bluetooth adapter, and select Update driver.
      • Choose Search automatically for updated driver software and complete the wizard.
      • Restart the PC if prompted, then test the headset.
    9. Check for Windows Updates and restart
      • Select Start > Settings > Windows Update.
      • Select Check for updates and install all available updates.
      • Then select Start > Power > Restart and test the headset again.
    If the headset still disconnects immediately after these steps, verify with the manufacturer’s documentation that it fully supports Windows 11 and standard Bluetooth audio profiles, and check for any device‑specific firmware updates.
  2. Jan J.23 13,925 Reputation points Independent Advisor
    2026-03-29T18:43:20.01+00:00
    Hi, I'm Jan, Does your headset connect via Bluetooth, or does it use a USB wireless dongle?
  3. Deleted
