Authenticator is not working!
Loretta Waynes 5 Reputation points
2026-03-24T16:33:36.7333333+00:00
My Authenticator is not working, what can I do to make it work?
Microsoft Security | Microsoft Authenticator
    2026-03-24T16:33:53.86+00:00
    Try the following steps in order, testing Authenticator after each change:
    1. Check network and connectivity
      • Make sure the phone has internet access.
      • If using mobile data, switch to Wi‑Fi; if using Wi‑Fi, switch to mobile data.
      • Ensure Airplane mode is off.
      • If using a VPN, disconnect it and try again.
    2. Update Authenticator and the device
      • Open the app store and install the latest version of Microsoft Authenticator. Microsoft does not support versions older than 12 months.
      • On the device, install any pending OS and security updates.
      • If using other Microsoft security apps (such as Microsoft Defender or Intune Company Portal), update them as well.
    3. Check app lock, notifications, and battery settings
      • Open Microsoft Authenticator and make sure the app is unlocked when trying to approve sign‑ins.
      • In Authenticator Settings:
        • Turn on App updates.
        • Turn off battery optimization for Authenticator for better sync performance.
        • Open Notification Settings and ensure Show notifications is turned on.
      • In the device’s system Settings, confirm notifications are allowed for Authenticator and not set to silent.
    4. Verify device date, time, and security state
      • Ensure the device’s Date & time are correct and set to automatic if possible.
      • Make sure the device is not jailbroken or rooted, as work/school Entra credentials in Authenticator will not function on such devices.
    5. If seeing specific error messages
      • “Authentication did not complete”
        • Ensure the app is unlocked.
        • Confirm notifications are enabled and not silent.
        • Confirm the app is updated and the device is online.
        • Verify date and time settings.
      • On Android work/school accounts with Google Play errors or setup issues (for example, “Google Play services are currently unavailable on this device” or “Sorry, only part of the set up completed successfully”):
        • Ensure Google Play Services and Google Play Store are installed and enabled.
        • Confirm push notifications are enabled for Authenticator.
        • Require a PIN or biometric to unlock the device; re‑enable face/fingerprint, restart the device, then unlock with that method and try enabling passwordless again.
        • If using Android for Work/Work Profile, enable PIN/biometric for that profile.
        • Ensure hardware encryption is enabled on the device (see Encrypt your Android device).
        • In Authenticator, go to Settings > Device Registration and confirm the account is registered for passwordless and joined to work/school; sign in there if needed, then try enabling passwordless again.
    6. If sign‑in still fails
      • If unable to sign in because of forgotten credentials, use the password reset flow: Reset your password.
      • For work/school accounts where nothing above helps, contact the organization’s IT admin or Microsoft Support/Data Protection team to reset MFA or Authenticator registration.
