MFA - "There's a temporary problem with the service. Please try again later"
Curtis Newton 0 Reputation points
2026-03-14T04:42:46.2933333+00:00
On my Microsoft (personal) account, I am trying to enable Two-Factor Authentication (MFA) and it doesn't matter if I use my Windows laptop, the Microsoft Authenticator App on my phone or a web browser in private mode, I am getting the error when trying to turn on MFA:
"There's a temporary problem with the service, Please try again later".I am able to log into my account, I can view my email, OneDrive, etc. I have multiple ways setup to authenticate and have no issues; however, I would like to use MFA as an added security feature.
I was able to chat with Microsoft, the tech took over my PC and the tried to enable the MFA feature, but received the same error. After a few attempts, he indicated there was an issue on Microsoft's back-end, but I would think there would be a lot more postings about the issue.
He even tried to remove the Authenticator as an option from my account and that produced an error and wouldn't let it be removed.
Anyone experienced this or any ideas how to fix it?
Microsoft Security | Microsoft Authenticator
    2026-03-14T04:43:00.06+00:00
    The error message indicates a problem with the multifactor authentication (MFA) service during setup, not with basic sign-in. From the available information, the supported actions are:
    1. Wait and retry later
    • The message explicitly indicates a temporary service problem. MFA and two-step verification services can block or throttle repeated attempts or show errors when there is unusual activity or a backend issue.
    • If there have been many attempts to turn MFA on or reconfigure it, wait before trying again. Microsoft Entra multifactor authentication can temporarily prevent additional attempts when it detects repeated sign-in or verification activity.
    1. Try a different MFA method or path
    • If multiple verification methods are already configured (phone, SMS, app, etc.), use Other verification options where available and confirm that each method works correctly.
    • If one method is failing during setup, switch to another method (for example, SMS instead of app, or app instead of phone call) and see whether the setup completes.
    1. Verify existing security verification data
    • Confirm that phone numbers and country/region codes are correct in the security verification settings, as incorrect data can cause repeated failures and error messages during MFA flows.
    1. Avoid repeated failed attempts
    • Repeated attempts can be interpreted as unusual activity. If there have been many failed or repeated MFA configuration attempts, pause and try again later or use a different MFA method. If sign-in attempts start failing as well, an admin should review Microsoft Entra sign-in logs for potential blocking or misconfiguration.
    1. If the account is work or school (Microsoft Entra ID)
    • Contact the organization’s IT help desk or Microsoft Entra administrator. They can:
      • Check sign-in logs and MFA status.
      • Reset MFA methods or require re-registration so MFA can be configured again.
      • Confirm whether there is any tenant-level policy or configuration affecting MFA setup.
    If the problem persists across devices and methods after waiting and retrying, and support has already reproduced the issue, further resolution will typically require Microsoft support or, for work/school accounts, the tenant administrator to investigate and possibly reset MFA or adjust policies.
