Surface Pro 10 "Disconnected" cellular data using a T-Mobile physical SIM card.
Julian Vesga 5 Reputation points
2026-03-12T01:13:39.9133333+00:00
I have a new Surface Pro 10 working with Windows 11. I already followed all the troubleshooting from the settings, reinstalling controllers, configuring the APN with technical support of T-Mobile, but nothing works.
  1. S.Sengupta 32,031 Reputation points MVP Volunteer Moderator
    2026-03-12T04:34:44.6333333+00:00
    If your **Microsoft Surface Pro 10 with Windows 11 cannot connect to cellular data even after troubleshooting, the issue is usually related to eSIM/SIM activation, drivers, or carrier compatibility.
    Does it support cellular hardware?
    Open Settings → Network & Internet
    Do you see Cellular in the menu?
    If Cellular appears → device supports 5G/eSIM
    If your device has cellular but modem is not detected, the best option is to contact Microsoft support.
    If Cellular is missing → your model does NOT have cellular hardware
    If it is Wi-Fi only, the best option is to use phone hotspot.
