why does this keep happening to me i cant fix it at all
Noman Niaz 0 Reputation points
2026-03-10T21:44:40.51+00:00
Screenshot 2026-03-10 212334
i clearly have a microsoft account as
please help sm1
Windows for home | Windows 11 | Accounts, profiles, and login
    2026-03-10T21:44:57.3933333+00:00
    The message “That Microsoft account doesn’t exist” means the email being entered is not currently recognized as a Microsoft account, even if it is used as a local sign‑in name on the PC.
    On Windows, the account shown under Settings → Accounts can be:
    • A local account that just happens to use an email address as the username, or
    • A Microsoft account that is actually registered online.
    If the sign‑in page says the Microsoft account doesn’t exist, that address is not registered (or not registered in exactly that form) as a Microsoft account.
    To fix this:
    1. Confirm the exact address and domain
      • Make sure the address is typed exactly the same as when the account was created (spelling, numbers, and domain such as .com, .co.uk, etc.).
      • Try any other email aliases or phone numbers that might have been used when first creating the Microsoft account.
    2. Use the official recovery flow
      • Go to Recover your account: https://account.live.com/password/reset
      • Enter each email/phone/Skype name that might be associated with the Microsoft account.
      • Follow the steps to receive a security code and reset the password if the account is found.
    3. If the email is truly not a Microsoft account
      • If none of the addresses are recognized, then the Windows sign‑in is most likely a local account only. In that case, create or link a Microsoft account separately and then use that for Microsoft services.
    4. If the problem continues
      • Run the Microsoft account sign‑in helper at https://aka.ms/sign-in-helper. It will check the sign‑in details and tell what needs to be done next.
      • If the helper still cannot find the account, use Contact support from the article below and explain that the username has stopped working.
