When print jobs disappear from the queue without printing, the Print Spooler service or its data is often corrupted. Since the queue reset did not help, use the deeper spooler and driver checks below on Windows 11.
- Clear the print queue from Settings
- Select Start > Settings > Bluetooth & devices > Printers & scanners.
- Select the printer and choose Open print queue.
- Right‑click each job and select Cancel until the list is empty.
- Restart the Print Spooler service
- Press Windows key + R, type
services.msc, press Enter. - Scroll to Print Spooler.
- Right‑click Print Spooler and select Restart.
- Try printing again from Word.
- Manually clear the spool folder (if jobs still vanish)
- Stop the Print Spooler service:
services.msc, press Enter. - Right‑click Print Spooler > Stop.
- Open File Explorer and go to
C:\Windows\System32\spool\PRINTERS. - Delete all files in this folder (these are stuck/corrupted spool files, not documents).
- Start the Print Spooler again:
- In services.msc, right‑click Print Spooler > Start.
- Print a small test document from Word.
- Check for driver issues (spooler crashes can silently drop jobs)
- Select Start, type Device Manager, open it.
- Expand Print queues or Printers.
- Uninstall any old, duplicate, or unused printer entries.
- Install the latest driver for the exact printer model from the printer manufacturer’s site.
- Test printing again.
- Check for no‑output conditions on the printer
If jobs appear briefly then disappear but nothing prints, treat it as a “no print output” scenario:
- In Settings > Bluetooth & devices > Printers & scanners, open the printer’s Printer properties.
- On the Advanced tab, clear Enable advanced printing features.
- Apply, then try printing again.
- If still failing, create a new printer queue for the same device (Add device again) and test printing through the new queue.
- Check the spool folder for persistent corruption
- Verify that after a successful print attempt, files in
C:\Windows\System32\Spool\Printersare removed automatically. - If old files remain or reappear, stop Print Spooler, move any remaining files out of that folder, then start Print Spooler and test again.
If, after these steps, Word jobs still vanish while other apps print correctly, the issue is likely specific to Office and further Office‑specific troubleshooting would be required.
