Billing Info
Tracy Batts 0 Reputation points
2026-03-05T12:03:13.4366667+00:00
How do I get a copy of a bill
  • date: 9 Feb 2026
  • amount: €104.99
  • descriptor: MICROSOFTSBILL.INFO
Microsoft 365 and Office | Subscription, account, billing | Other | Other
    2026-03-05T12:03:30.4133333+00:00
    To get a copy of the bill for a Microsoft charge like the one described, first identify which Microsoft service it belongs to, then use the corresponding billing portal to view and download the invoice.
    For Microsoft 365 or other Microsoft subscriptions managed through the Microsoft 365 admin center:
    1. Go to the Microsoft 365 admin center: https://go.microsoft.com/fwlink/p/?linkid=2024339
    2. In Simplified view: select Products, then View invoices.
      • In Dashboard view: go to Billing > Bills & payments.
    3. If there is more than one billing account, select Change billing account and check each account.
    4. Adjust the date range so it includes 9 Feb 2026.
    5. Look for an invoice whose total is €104.99.
    6. Select that invoice to view details.
    7. To get a PDF copy, select Download, then Download invoice.
    If the charge is from the Microsoft Store (for example, apps, games, or one‑time purchases):
    1. Sign in to the order history page at https://account.microsoft.com/billing/orders.
    2. Make sure the correct Microsoft account is used.
    3. Under Refine, set the order and date range to include 9 Feb 2026.
    4. Find an order with amount €104.99 and status Completed or Redeemed.
    5. Select Order details.
    6. To print or save an invoice, use Print on the Order details page (or the browser’s print function) to generate a copy.
    If a tax invoice is required for a Microsoft Store purchase and it is not immediately available:
    1. In the same Order history page, open the relevant order’s Order detail.
    2. When available (typically 48 hours to 5 days after purchase), select Tax invoice to download the tax invoice.
    If the charge is for Azure usage (for example, an Azure subscription tied to the same payment method):
    1. Go to the Azure portal Subscriptions page: https://portal.azure.com/#blade/Microsoft_Azure_Billing/SubscriptionsBlade.
    2. Select the subscription that might match the charge.
    3. Select Invoices.
    4. In the invoice list, locate the billing period that covers 9 Feb 2026 and look for an invoice whose total is €104.99.
    5. Select the download symbol, then Download invoice to get the PDF.
    If none of the above portals show an invoice matching the date and amount, contact Microsoft support for billing assistance via the appropriate product’s support channel and provide the date, amount (€104.99), and descriptor (MICROSOFTSBILL.INFO) so they can locate the transaction.
