New Surface Pro not compatible with Brother HL-2270DW printer
SirGnarlyDude 0 Reputation points
2026-02-28T03:17:26.34+00:00
Windows 11 finds the printer, but says Driver Incompatible
  1. S.Sengupta 32,031 Reputation points MVP Volunteer Moderator
    2026-02-28T05:32:25.6933333+00:00
    Brother has not released an Arm64 driver for this model.
    As a result, the Surface sees the printer but can’t load a proper driver, so it doesn’t install or work correctly.
    Sometimes Windows’ generic Mopria drivers will support basic printing over Wi-Fi .Try to add the printer via Settings → Bluetooth & devices → Printers & scanners and select the network-listed Brother printer.
