ACS Call Automation PlayFailed error 8565 on TTS despite correct managed identity, role assignment, and multi-service Cognitive Services connection
Sivakumar, Vidhya 0 Reputation points
2026-02-25T07:05:46.1766667+00:00
Environment:
  • Azure Communication Services: amn-acs-prod (United States, global)
  • Cognitive Services: multi-service CognitiveServices kind, West US 2, S0 SKU
  • SDK: @azure/communication-call-automation v1.5.1
  • Function App: Azure Functions (Node.js)
Problem:
Every playToAll TTS call fails immediately with:
json
  "code": 400,
  "subCode": 8565,
  "message": "Action failed due to a bad request to Cognitive Services. Please check your input parameters."
The call connects successfully, CallConnected fires, playToAll returns HTTP 202, but PlayFailed with 8565 arrives ~1 second later every single time.
Everything configured correctly:
  • ✅ Multi-service CognitiveServices resource (not single Speech)
  • ✅ System-assigned managed identity enabled on ACS
  • ✅ Cognitive Services User role assigned to ACS managed identity at the Cognitive Services resource scope
  • ✅ Resource connected via Portal under ACS → Cognitive Services
  • ✅ cognitiveServicesEndpoint passed in answerCall options
  • ✅ Voice en-US-JennyNeural confirmed available in West US 2 via Voices List API
  • ✅ No network/firewall restrictions on Cognitive Services resource
Code:
javascript
const answerOptions = {
  callIntelligenceOptions: {
    cognitiveServicesEndpoint: "https://westus2.api.cognitive.microsoft.com"
await client.answerCall(incomingCallContext, callbackUri, answerOptions);
// Later on CallConnected:
await callMedia.playToAll([{
  kind: "textSource",
  text: "Welcome to AMN Healthcare.",
  voiceName: "en-US-JennyNeural",
  sourceLocale: "en-US"
}], { operationContext: "greeting" });
Things already tried:
  • Multiple Cognitive Services resources (eastus, westus2, single Speech, multi-service)
  • Both regional endpoint format (https://westus2.api.cognitive.microsoft.com) and resource-specific format (https://amn-ai-multisvc-prod.cognitiveservices.azure.com)
  • With and without trailing slash on endpoint
  • With and without cognitiveServicesEndpoint in answerCall (Portal connection alone)
  • Multiple voice names (NancyNeural, JennyNeural)
  • Waited 10+ minutes for RBAC propagation between attempts
  • Verified role assignment via az role assignment list --scope <resource-id>
Correlation IDs:
  • 0448001e-4c4b-4745-9faf-cabcf51af303
  • 882d1b82-3188-4dbf-80e3-5ed9a1ea7d3b
  • 6aef40b4-de1e-41e3-b528-08837dd1104a
Question:
Is there something beyond RBAC + Portal connection + correct endpoint that's required? Is there a known issue with new subscriptions or specific regions? The Portal connection UI also fails intermittently with a generic error when trying to connect the Cognitive Services resource, which makes me think there may be a backend provisioning issue.
Any help appreciated — this has been blocking for several hours.
That gives the community everything they need to help quickly.
Sonnet 4.6json
Code:
javascript
const
Correlation IDs:
Question:
    2026-02-25T07:06:25.83+00:00
    The error code 8565 indicates that the action failed due to a bad request to Cognitive Services, which suggests that there may be an issue with the input parameters being sent to the service. Here are some steps you can take to troubleshoot this issue further:
    1. Verify Input Parameters: Ensure that the parameters being passed to the playToAll method are correctly formatted. Double-check the text, voiceName, and sourceLocale values to make sure they are valid and supported by the Cognitive Services resource.
    2. Check Voice Availability: Although you confirmed that en-US-JennyNeural is available, it might be worth testing with other voices to see if the issue persists. Sometimes, specific voices may have transient issues.
    3. Cognitive Services Configuration: Ensure that the Cognitive Services resource is properly configured and that the multi-service setup is functioning as expected. You might want to check the Azure portal for any alerts or notifications regarding the Cognitive Services resource.
    4. Role Assignment: Confirm that the role assignment for the managed identity is correctly set and that there are no additional permissions required for the specific actions you are trying to perform.
    5. Backend Provisioning Issues: Since you mentioned intermittent failures when connecting the Cognitive Services resource via the portal, it is possible that there might be backend provisioning issues. You could reach out to Azure support to check if there are any known issues in your region or with your subscription.
    6. Logs and Monitoring: Utilize Azure Monitor or Application Insights to gather more detailed logs and telemetry data about the requests being made to Cognitive Services. This might provide more context on why the requests are failing.
    If the issue persists after checking these areas, consider reaching out to Azure support with the correlation IDs you provided, as they can assist in diagnosing the issue further.
