Identity Verification in Artifact Signing said Verification Successful but still shows Action Required
Azmat Zuberi 0 Reputation points
2026-02-25T01:39:24.3033333+00:00
I created a verified ID for Artifact Signing and have the ID on my MS Authenticator. It still says Action Required?
Artifact Signing
Artifact Signing
A fully managed end-to-end service for digitally signing code, documents, and applications. (formerly Trusted Signing)
    2026-02-25T01:39:31.4333333+00:00
    If you see the status as "Action Required" even after the verification shows as successful, it may be due to a couple of reasons:
    1. Pending Updates: It can take a few minutes for the Identity Validation status on the Azure portal to update after the verification process is completed. You may need to wait a bit longer to see the status change from "Action Required" to "Completed".
    2. Verification Process: Ensure that you have followed all steps correctly in the verification process. If there was any step missed or if there are discrepancies in the information provided, it may still show as "Action Required".
    If the issue persists, consider reaching out to Azure support for further assistance.
