How do I fix my account not recieving a code?
Wian Rheeders 0 Reputation points
2026-02-16T14:09:42.2933333+00:00
I have a work email which doesn't recieve the code; not the on-screen code or the one-time password code; to allow me to log into my account. I need to log into that account because I have to update personal details on my workspace which I can't do because I'm not recieving a code at all. I am logged into the Authenticator app with my work email but I still do not get a code of any kind.
Microsoft Security | Microsoft Authenticator
    2026-02-16T14:09:52.28+00:00
    If you are not receiving a code from the Microsoft Authenticator app, there are a few steps you can take to troubleshoot the issue:
    1. Check Your Internet Connection: Ensure that your device has a stable internet connection, as the Authenticator app requires it to generate codes.
    2. Verify Account Setup: Make sure that your work email is correctly set up in the Authenticator app. You may need to remove and re-add the account to ensure it is configured properly.
    3. Alternative Sign-in Methods: If you have alternative sign-in methods set up (like SMS or email verification), try using those methods to log in.
    4. Contact Your Administrator: If you are part of an organization, reach out to your IT administrator. They may need to reset your multi-factor authentication (MFA) settings or check if there are any issues with your account.
    5. Use a Temporary Account: If you are unable to resolve the issue through the above steps, consider creating a temporary Microsoft 365 tenant (trial account) to access the admin console and submit a support ticket requesting assistance from the Data Protection team.
    6. Contact Microsoft Support: If all else fails, contacting Microsoft support directly may be necessary. Be prepared to explain your situation clearly to get the help you need.
    These steps should help you regain access to your account and resolve the issue with not receiving codes.
